Home » Newcomers » Newcomers » Error registering XML parser services
Error registering XML parser services [message #29016] Fri, 25 February 2005 00:40 Go to next message
Originally posted by: pingshun.loh.gmail.com
Hi, I just unzipped Eclipse and is new to JAVA. When I tried to run
eclipse.exe from my desktop, it gives me the error: "Error registering XML
parser services". Also, how do I check whether VM is on my machine.
Thanks in advance.
Re: Error registering XML parser services [message #29165 is a reply to message #29016] Fri, 25 February 2005 01:03 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
You need a 1.4 VM. Run "java -version" to see what your default is.
See also:
http://www.eclipsefaq.org/chris/faq/html/faq25.html
Chris Laffra, http://eclipsefaq.org
"PS Loh" <pingshun.loh@gmail.com> wrote in message
news:cvmdno$kjn$1@www.eclipse.org...
> Thanks in advance.
Re: Error registering XML parser services [message #29203 is a reply to message #29165] Fri, 25 February 2005 01:09 Go to previous messageGo to next message
> See also:
After running java -version, it prints java version "1.3.1"
Where can I get VM and how do I load it?
Thanks for your prompt reply
Re: Error registering XML parser services [message #29392 is a reply to message #29203] Fri, 25 February 2005 08:06 Go to previous message
Just use Google and search for "download JRE".
Install it, and then use the instructions in FAQ 25.
news:cvmfer$qge$1@www.eclipse.org...
> > See also:
Previous Topic:Can't change the font color of Java Editor
Next Topic:Swing plugin for Solaris?
Current Time: Fri Jul 04 11:40:34 EDT 2025
Powered by FUDForum. Page generated in 0.10601 seconds
