Re: Build with PDE Build [message #289963 is a reply to message #289944] |
Tue, 16 August 2005 02:50 |
Originally posted by: pascal.ibm.canada
Come on, it's well documented. It says "/plugin or feature
id/path/to/.product" :-)
More seriously, this will take care of the branding. To use, you need to
refer to the doc product file like in your second proposal.
PaScaL
Martin Jäger wrote:
> Hi there
> I'm trying to build a RCP project outside of eclipse with pde-build. The
> fetching from cvs, compiling, and packaging of the features works fine.
> Now, I saw in the 3.1 build.properties template an undocumented
> property: "product".
> What does it do? Does it uses my product to adjust the .exe image and
> packages the branding also?
> How do I use it?
> product=myProduct.product
> or
> product=ch.netcetera.myplugin/myProduct.product
> I never see something in the log about it.
> Thanks a lot
> Martin
Re: Build with PDE Build [message #290274 is a reply to message #290192] |
Mon, 22 August 2005 17:19 |
Originally posted by: greg.akins.am.sony.com
Martin Jäger wrote:
> Hi Greg
> I never used it like you want to do. I built it like it is described in
> the excellent article here:
> http://www.eclipse.org/articles/Article-PDE-Automation/autom ation.html
Thanks! I read that article, and am having more luck as I work backwards
through that, rather than trying to implement my own build from scratch.
> Additionally, I hope it is possible to export a product complete in
> Eclipse 3.1... without human interaction.
Unless I misunderstand, this is impossible. There is a bug report with a
fair amount of commentary requesting this very thing (Sorry, I don't have
a bug number, you could look at Bugzilla).
I'm in the progress of trying to get my first PDE build, with the
intention of reverse engineering the resulting Ant scripts to make it less
dependent on Eclipse to build. But haven't made much progress yet.
There is an Maven Mevenide project (Maven Eclipse Plugin Plugin) that
appears to be a build tool for Eclipse plugins. But I'm not sure how
mature that project is; and whether it's for just plugins or full RCP
applications.
FUDForum. Page generated in 0.03006 seconds
