Open External File from a class implementing IStartup [message #289485] |
Fri, 05 August 2005 15:02 |
Originally posted by: no_email_please.hotmail.com
Is there a way of triggering an OpenExternalFileAction within a class
implementing IStartup (or during startup)?
So far I've got this:
IWorkbench workbench = PlatformUI.getWorkbench();
File file = new File(myFilePath);
IPath path = new Path(file.getAbsolutePath());
IEditorInput input = new
FileEditorInput(ResourcesPlugin.getWorkspace().getRoot().get File(new
Path(file.getAbsolutePath())));
try{
IWorkbenchWindow window = workbench.openWorkbenchWindow(input);
window.openPage(input);
}catch(Exception e){
System.out.println(e);
The problem is that the current thread is not the display thread so when I
try to create my window object, I get invalid thread access.
Any ideas?
Nic
Re: Open External File from a class implementing IStartup [message #289497 is a reply to message #289495] |
Fri, 05 August 2005 17:43 |
Thanks, that seems to work.... but not completely. It's a good step forward
though.
The problem now is that it opens a second workbench... I just need a
workbench page (I think that's what it's called) or editor to open.
This is what I do now:
final IWorkbench workbench = PlatformUI.getWorkbench();
myTest t = new myTest();
t.setFilePath(filename);
t.setWorkbench(workbench);
workbench.getDisplay().asyncExec(t);
class myTest implements Runnable{
private String myFilePath;
private IWorkbench myWorkbench;
public void setFilePath(String filepath){
myFilePath = filepath;
public void setWorkbench(IWorkbench workbench){
myWorkbench = workbench;
public void run() {
IWorkbenchWindow window = myWorkbench.getActiveWorkbenchWindow();
try{
if (window != null){
IWorkbenchPage iwp = window.openPage(input);
iwp.openEditor(input, "org.eclipse.ui.DefaultTextEditor");
"nicolas" <nico.mook@laposte.net> wrote in message
news:b2633cf70a2171bcf9d0ca3693361f81$1@www.eclipse.org...
> Have you tried to make your action in a syncExec/asyncExec call ?
> Display.getDefault().asyncExec(new Runnable() {
> public void run() {
> ...your code ...
> Tchuss,
> Nico.
FUDForum. Page generated in 0.02948 seconds
