Home » Eclipse Projects » Eclipse Platform » how to view source in ie using eclipse
how to view source in ie using eclipse [message #289015] Wed, 27 July 2005 11:04 Go to next message
Originally posted by: pete.ford.name
By using Microsoft's TweakUI powertoy I am able to set which application
will be launched when you select 'view source' in Internet Explorer.
However, when it set it to use eclipse.exe every time I view source it
launches a new instance of Eclipse (and warns that the workspace is already
in use).
Instead, I want it to just open the source in the currently running Eclipse.
Is there a way to do this???
Re: how to view source in ie using eclipse [message #289033 is a reply to message #289015] Wed, 27 July 2005 13:28 Go to previous message
Hi Peter,
This is a question for the Eclipse platform. Assuming there is a way to do
this the WTP editors can be used. Try posting your question to the
eclipse.platform newsgroup.
Lawrence
Previous Topic:Partition scanner versus rule-based scanner
Next Topic:Eclipse Help System Error
Current Time: Mon Jul 21 22:52:50 EDT 2025
Powered by FUDForum. Page generated in 0.03533 seconds
