Home » Newcomers » Newcomers » Eclipse won't start
Eclipse won't start [message #28765] Wed, 23 February 2005 12:07
Originally posted by: edward.born-digital.co.uk
Running Eclipse 3.0.1, Sun jdk 1.4.2_06, Linux kernel 2.6.9, Athlon x86.
Eclipse fails to start and reports an error; the log file gives the
stack trace below.
The permissions for .fileTableLock are set to 744, eclipse was started
by the file owner. The filesystem is ext3fs
(using the Eclipse-linux gtk binary, not the gentoo ebuild)
SESSION Feb 23, 2005 16:47:43.419
eclipse.buildId=M200409161125
java.version=1.4.2-gentoo
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY
initial@reference:file:/opt/eclipse/plugins/org.eclipse.core.runtime_3.0.1/
0 0 Feb 23, 2005 16:47:43.457
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.runtime.PlatformActivator.start() of bundle
org.eclipse.core.runtime.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:975)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:366)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:999)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:577)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:488)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:444)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:186)
org.eclipse.osgi.framework.eventmgr.EventThread.run(EventThr ead.java:104)
Caused by: java.io.IOException: An error occurred while locking file
" /home/edward/.eclipse/org.eclipse.platform_3.0.1/configurati on/org.eclipse.core.runtime/.manager/.fileTableL$
org.eclipse.core.runtime.adaptor.Locker_JavaNio.lock(Locker_ JavaNio.java:42)
org.eclipse.osgi.service.datalocation.FileManager.lock(FileM anager.java:219)
org.eclipse.osgi.service.datalocation.FileManager.open(FileM anager.java:423)
org.eclipse.core.internal.runtime.InternalPlatform.initializ eRuntimeFileManager(InternalPlatform.java:391)
org.eclipse.core.internal.runtime.InternalPlatform.start(Int ernalPlatform.java:384)
org.eclipse.core.internal.runtime.PlatformActivator.startInt ernalPlatform(PlatformActivator.java:251)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:64)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
... 10 more
Root exception:
" /home/edward/.eclipse/org.eclipse.platform_3.0.1/configurati on/org.eclipse.core.runtime/.manager/.fileTableLock ":
"Valu$
Previous Topic:No application id has been found
Next Topic:Multiple Eclipses in the same PC possible ?
Current Time: Tue May 13 17:57:04 EDT 2025
Powered by FUDForum. Page generated in 0.08023 seconds
