Home » Eclipse Projects » Eclipse Platform » Remove "links" folder
Remove "links" folder [message #287493] Thu, 30 June 2005 20:47 Go to next message
I'm using the "links" folder to include one of my plugins. And everything
is working as expected. Then I realized I included the wrong plugin
version, so I just deleted the whole "links" folder and restarted eclipse.
And my plugin is still loaded (all the features are still available.)
Then I manually removed the my plugin's site node from platform.xml, and
restart, and the feature is still there!! This used to work in Eclipse
3.0. Is this a bug in 3.1? Whewe is this information being cached?
Thanks for any information!!
Re: Remove "links" folder [message #287503 is a reply to message #287493] Fri, 01 July 2005 06:08 Go to previous messageGo to next message
Ling,
It's cached in the configuration directory. Running eclipse.exe with
-clean will clean the configuration. (Apparently you can also delete
everything but the configuration/config.ini, if you want to make it be
in the same state as when you first installed/unzipped.)
> everything is working as expected. Then I realized I included the
> wrong plugin version, so I just deleted the whole "links" folder and
> restarted eclipse. And my plugin is still loaded (all the features are
> still available.) Then I manually removed the my plugin's site node
> from platform.xml, and restart, and the feature is still there!! This
> used to work in Eclipse 3.0. Is this a bug in 3.1? Whewe is this
Re: Remove "links" folder [message #287530 is a reply to message #287503] Fri, 01 July 2005 13:22 Go to previous message
Thanks! But -clean did not remove the feature from the running app. I had
to remove my plugin folder (the one the old link file was pointing to)
Previous Topic:how to call the functions of one plugin though code from another plugin?
Next Topic:Classes not found
Current Time: Tue Jul 15 12:23:36 EDT 2025
Powered by FUDForum. Page generated in 0.29009 seconds
