[ANN] Jetty Launcher plugin 1.0.2 [message #28732] |
Wed, 07 May 2003 18:18 |
Originally posted by: glongman.intelligentworks.nospam.com
Much, much improved. Classpath entries are regulated now. If you want JMX,
SSL, or JSP support at runtime, there are check boxes on a tab. Users
familliar with launching Jetty from $JETTY_HOME$ get more help now as the VM
directive -Djetty.home is now automatically set. Plus the Quick Start guide
installs itself in Eclipse Help.
Thanks to all who tried it out and sent feedback, particularly Dolf and
Piotr.
Full details are available in the Quick Start guide at the link below
Follows is the orginal announcement...
Install the plugin, select your project, click Run->Run, New Jetty Web.
Select the place on your drive where a Jetty dstro has been extracted, enter
the port and the folder in your project that will be context root, hit
"Run". That's it.
Or you can specify an xml file that Jetty understands, so you stay in
complete control.
Jetty Launcher was built by the Spindle team.
~240k download, Update site: http://spindle.sourceforge.net/updates.
Quick Start Guide at http://spindle.sourceforge.net/jettylauncher
Geoff
Geoffrey Longman
Intelligent Works Inc.
FUDForum. Page generated in 0.04030 seconds
