Xbase: type computation of switch's case expressions [message #1552909] |
Thu, 08 January 2015 06:42  |
I noted that the XbaseTypeComputer computes the type of the case
expressions without type expectation from the switch expression; it just
does this
ITypeComputationState caseState = casePartState.withNonVoidExpectation();
Is that intentional?
This leads to this code in Xtend to be compiled fine
def sw(char c) {
switch(c) {
case '01' : println(0) // this should be a type mismatch
it is compiled to this Java code
public Integer sw(final char c) {
Integer _switchResult = null;
boolean _matched = false;
if (!_matched) {
if (Objects.equal(c, "01")) {
_matched=true;
_switchResult = InputOutput.<Integer>println(Integer.valueOf(0));
return _switchResult;
But shouldn't it raise a compilation error saying that it expects a char
instead of a String?
cheers
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Xbase: type computation of switch's case expressions [message #1553189 is a reply to message #1552995] |
Thu, 08 January 2015 09:57  |
On 08/01/2015 13:40, Sebastian Zarnekow wrote:
> Hi Lorenzo,
> Xtend lacks some validation for equality comparison of instances of
> provable distinct types. This would detect the bogus case in your snippet.
> Generally speaking it is valid to do something along these lines:
> def Object someObject() {
> return 'string';
> def String someString() {
> return 'string'
> switch someString() {
> case someObject(): println('')
> Here you see that the expectation would have produced a type mismatch
> even though this code is fine at runtime.
Hi Sebastian
OK, I see; indeed Xbase switch statement is much more powerful than
Java's one.
In my case (yes, still the stricter Xbase/Java version I'm working on),
I just had to add an additional check in the validator and I get my
desired type mismatch back :)
@Check
def void checkSwitch(XSwitchExpression sw) {
val switchExpressionType = getActualType(sw.^switch)
for (c : sw.cases) {
val caseType = getActualType(c.^case)
if (!switchExpressionType.isAssignableFrom(caseType)) {
error(
String.format("Type mismatch: cannot convert from %s to %s",
caseType.humanReadableName, switchExpressionType.humanReadableName
c,
XbasePackage.eINSTANCE.XCasePart_Case,
IssueCodes.INCOMPATIBLE_TYPES
cheers
Lorenzo
Xtext Book:
FUDForum. Page generated in 0.03002 seconds
