Home » Eclipse Projects » Eclipse Platform » Generating links to Java API in my JavaDocs
Generating links to Java API in my JavaDocs [message #287062] Thu, 23 June 2005 12:00 Go to next message
Originally posted by: bradley.wagner.hannonhill.com
Hi, I am trying to generate JavaDocs for my project. I have setup the rt.jar file to use:
http://java.sun.com/j2se/1.4.2/docs/api/ as the location for Java's API. However, when I generate my
own docs no links are created to types like java.lang.String. Instead, it's just the plain text
'java.lang.String'. I was looking at the documentation for Apache's Cocoon project which definitely
has links to the Java API. Take a look:
http://cocoon.apache.org/2.1/apidocs/org/apache/cocoon/Cocoo n.html#getSystemProperty(java.lang.String,
java.lang.String)
Any thoughts?
Bradley
Re: Generating links to Java API in my JavaDocs [message #287066 is a reply to message #287062] Thu, 23 June 2005 13:04 Go to previous messageGo to next message
Originally posted by: chaves-do-not-spam.inf.ufsc.br
Use the -link command line option for javadoc (the Javadoc wizard allows
you to to that). For instance:
-link http://java.sun.com/j2se/1.4.2/docs/api
More info:
http://java.sun.com/j2se/1.4.2/docs/tooldocs/windows/javadoc .html#link
file to use:
> java.lang.String)
> Any thoughts?
> Bradley
Re: Generating links to Java API in my JavaDocs [message #287074 is a reply to message #287066] Thu, 23 June 2005 14:25 Go to previous message
Is there any way to automate this for ALL the jar files in my project? These jars all have links to
their JavaDocs setup.
Bradley
> More info:
Previous Topic:ICharacterScanner.unread() should return an error if I unread to many times
Next Topic:What's wrong with my eclipse in FC4Linux
Current Time: Wed Jul 16 17:18:28 EDT 2025
Powered by FUDForum. Page generated in 0.03851 seconds
