Home » Eclipse Projects » Eclipse Platform » How can I launch a wizard from code?
How can I launch a wizard from code? [message #286877] Mon, 20 June 2005 17:37 Go to next message
Originally posted by: pbeagan.yahoo_nospam_.com
Anyone know what code is needed to launch a wizard?.
Specifically, I want the user to be able to right-click on the Project
Explorer, select a menu item 'MyWizard', and have the wizard start.
Creating the popupMenu IViewActionDelegate object is straightforward,
I figure I can just put some code in the run() menu to invoke 'MyWizard'.
I put the following code in the run() method but it leads to the exception
below:
INewWizard wiz = new MyWizard();
wiz.init(PlatformUI.getWorkbench(), null);
Unhandled event loop exception
Reason:
myproj/eclipse/project/wizard/MyWizard
Thanks!
Re: How can I launch a wizard from code? [message #286970 is a reply to message #286877] Wed, 22 June 2005 05:19 Go to previous message
> below:
This works for me:
public class MyAction implements IWorkbenchWindowActionDelegate {
private ISelection currentSelection;
public void run(IAction action) {
if(currentSelection instanceof IStructuredSelection) {
NewModelWizard wizard = new NewModelWizard();
wizard.init(
(IStructuredSelection) currentSelection);
public void selectionChanged(IAction action, ISelection selection) {
currentSelection = selection;
....where NewModelWizard is
public class NewModelWizard extends Wizard implements INewWizard {...}
HTH René
Previous Topic:How can i make an Eclipse plug-in from a C++ application?
Next Topic:Using the Eclipse code formatter on .java files
Current Time: Fri Jul 18 17:21:42 EDT 2025
Powered by FUDForum. Page generated in 0.05725 seconds
