Home » Newcomers » Newcomers » CVS Setup
CVS Setup [message #28626] Mon, 21 February 2005 10:59 Go to next message
Originally posted by: cneller.go.com
I've got eclipse 3.0.1 on my machine and CVS 1.10 set up on another. I
can check in an check out files from cvs, but when I use the "Compare With
> Latest from Head" in the Java perspective or "Open in Compare Editor" in
the Team Synchronization perspective, I get an error ("The server reported
an error while performing the "cvs update" command") with no additional
details.
I know I'm authenticating properly because I can do other cvs commands
through eclipse. So, what is my problem here?
Many Thanks,
-C
Re: CVS Setup [message #28632 is a reply to message #28626] Mon, 21 February 2005 12:39 Go to previous messageGo to next message
Originally posted by: SamMesh.gmail.com
> reported an error while performing the "cvs update" command")
You definitely do not have permissions for update on the CVS server.
(Dunno why compare requires update.:)
Sam Mesh
Re: CVS Setup [message #28637 is a reply to message #28632] Mon, 21 February 2005 13:35 Go to previous messageGo to next message
I can do a cvs update using WinCVS or when I am remotely logged into the
server, so I don't think the server is the issue. Are there permissions
in eclipse that I'm not aware of that could affect this? I would expect
that since I can add files and commit changes that I should be able to
update as well.
-C
Re: CVS Setup [message #28710 is a reply to message #28637] Tue, 22 February 2005 11:22 Go to previous messageGo to next message
> update as well.
So, you can update/commit from Eclipse?
Are user/protocol in Eclipse the same as in WinCVS?
Can you 'ls -l' your cvsroot to see actual permissions?
Sam Mesh
Re: CVS Setup [message #28716 is a reply to message #28710] Tue, 22 February 2005 12:33 Go to previous message
Yes, update and commit work just fine. It's just the compare features
that give the, oddly worded, "The server reported an error while
performing the "cvs update" command" error.
Yes, both use the same user and pserver protocol.
drwxrwxr-x 37 Admin cvs 1258 17 Feb 08:59 CVSROOT
My user should be in the proper group.
Is it possible this is a version conflict somewhere? I have eclipse 3.0.1
and I believe the cvs version is 1.10.
-C
Previous Topic:Search Results and Refactoring
Next Topic:how to apply patch?
Current Time: Sat Aug 30 14:54:25 EDT 2025
Powered by FUDForum. Page generated in 0.08078 seconds
