Error when activating Bundle [message #286046] |
Wed, 01 June 2005 05:39 |
I keep getting :
!MESSAGE An error occured while automatically activating bundle
com.nds.france.eclipse.mediahighway (140).
!STACK 0
org.osgi.framework.BundleException: The activator
com.nds.france.eclipse.mediahighway.MhdkBasePluginForEclipse for bundle
com.nds.france.eclipse.mediahighway is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:151)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:321)
I have made a plugin and try to build an archive (.jar) containing it like
this
com.nds.france.eclipse.mediahighway_1.0.0.jar
|____plugin.xml
|____com/nds/MyClass.class
here a short part of the plugin.xml
<?eclipse version="3.0"?>
<plugin
id="com.nds.france.eclipse.mediahighway"
name="MHDK base plugin for Eclipse"
version="1.0.0"
provider-name="NDS Technologies France"
class=" com.nds.france.eclipse.mediahighway.MhdkBasePluginForEclipse ">
<requires>
<import plugin="org.eclipse.ui"/>
</requires>
<extension-point id="signaling" name="MHDK execution signaling"
schema="schema/signaling.exsd"/>
<!-- Define MHDK Project nature -->
<extension
id="nature.id"
name="%mhdkNature"
point="org.eclipse.core.resources.natures">
<runtime>
<run
class=" com.nds.france.eclipse.mediahighway.nature.MhdkProjectNature ">
</run>
</runtime>
<requires-nature id="org.eclipse.jdt.core.javanature"/>
</extension>
Is it possible to build a plugin in a jar, do I need to make it an OSGI
bunble with a dedicated manifest? why this does not work????
thanks.
SeB.
FUDForum. Page generated in 0.06542 seconds
