Home » Newcomers » Newcomers » newbie needs urgent help please
newbie needs urgent help please [message #28546] Fri, 18 February 2005 13:27 Go to next message
Originally posted by: rudy-e.gmx.net
I'm new to eclipse and the world of java programming. I have been using
eclipse for 3 days now every thing was good.I just did some
installations(this time other tools.Now eclipse doesn't start again. I
found this line of message in a file(Eclipse directed me to) in the
configuration folder.
!MESSAGE Bundle
initial@reference :file:c:/Eclipse/eclipse/plugins/org.eclipse.core.runtime_3. 0.1/
[1] was not resolved.
What should I do? Help please.Thanks
Re: newbie needs urgent help please [message #28561 is a reply to message #28546] Fri, 18 February 2005 16:42 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
Remove everything in the configuration directory, except for the config.ini
file and try again.
Hope that helps,
Chris Laffra, http://eclipsefaq.org
"Rudy" <rudy-e@gmx.net> wrote in message
news:cv5c2l$ttu$1@www.eclipse.org...
> !MESSAGE Bundle
initial@reference:file:c:/Eclipse/eclipse/plugins/org.eclipse.core.runtime_3
..0.1/
Re: newbie needs urgent help please [message #28573 is a reply to message #28561] Sat, 19 February 2005 07:09 Go to previous messageGo to next message
> file and try again.
> Hope that helps,
hi Chris,
Thanks. I did remove every thing in the configuration directory but the
problem still persist. Is there any other solution to this problem? Please
Help.
Re: newbie needs urgent help please [message #28577 is a reply to message #28573] Sat, 19 February 2005 10:32 Go to previous messageGo to next message
While installing the other tools, you probably corrupted your existing
configuration.
I would reinstall eclipse in a different directory and try again.
news:cv7a9j$d46$1@www.eclipse.org...
config.ini
> > file and try again.
> > Hope that helps,
> hi Chris,
> Help.
Re: newbie needs urgent help please [message #28600 is a reply to message #28577] Sun, 20 February 2005 23:15 Go to previous messageGo to next message
> configuration.
I did reinsatll eclipse in another directory but the problem still
pserist.I deinsatll and reinstall java SDk but the problem still persist.
HERE IS THE ERROR MESSAGE located in the configuration directory.
!SESSION Feb 20, 2005 20:02:40.247
eclipse.buildId=M200409161125
java.version=1.3.1_01
!ENTRY org.eclipse.osgi Feb 20, 2005 20:02:40.247
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(EclipseAdaptor.java:272)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdaptor.java:253)
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemBundleActivator.java:61)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:553)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:477)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:243)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:166)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.osgi Feb 20, 2005 20:02:40.307
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: org/xml/sax/helpers/DefaultHandler
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginConverterImpl.java:557)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginConverterImpl.java:111)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginConverterImpl.java:660)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:233)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundleData.java:191)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundleData.java:159)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseBundleData.java:280)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initializeNewBundle(DefaultBundleData.java:77)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(DefaultAdaptor.java:451)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:746)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:715)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:659)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:219)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:800)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:429)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
!ENTRY org.eclipse.osgi Feb 20, 2005 20:02:40.317
!MESSAGE Bundle
initial@reference :file:c:/eclipse-SDK-3.0.1-win32/eclipse/plugins/org.eclipse .core.runtime_3.0.1/
COULD ANY ONE HELP ME? I WOULD RELY MUCH APPRECIATE ANY HELP.THANKS
Re: newbie needs urgent help please [message #28602 is a reply to message #28600] Mon, 21 February 2005 00:38 Go to previous messageGo to next message
Originally posted by: windheavennights.aol.com
I am having this very same problem. I had a previously installed java SDK
on my hard drive and then I downloaded eclipse as a zip file and extracted
it to where I wanted it. I then tried to run the program but it said I
needed the JRE. I downloaded that and installed it and then I recieved
this same error. I am not sure why this is occuring. I reinstalled my java
sdk's and the JRE as well as unzipped eclipse again. Any help would be
much appreciated.
James
Rudy wrote:
>> configuration.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Bundle
Re: newbie needs urgent help please [message #28616 is a reply to message #28602] Mon, 21 February 2005 07:50 Go to previous messageGo to next message
You need a 1.4 VM to run Eclipse 3.0. See the note on the download page.
"James" <windheavennights@aol.com> wrote in message
news:cvbs4h$h66$1@www.eclipse.org...
> much appreciated.
> James
> Rudy wrote:
> >> configuration.
> > Hi,
persist.
> > !STACK 0
> > at
> > at
r.java:253)
> > at
> > at
xtImpl.java:958)
> > at
> > at
xtImpl.java:937)
> > at
> > at
lManager.java:477)
> > at
> > at
Manager.java:243)
> > at
va:166)
> > at
> > at
216)
> > at
> > !STACK 1
> > at
> > at
> > at
> > at
undleData.java:233)
> > at
eData.java:191)
> > at
Data.java:159)
> > at
undleData.java:280)
> > at
> > at
> > at
ramework.java:746)
> > at
> > at
ava:715)
> > at
ava:659)
> > at
> > at
r.java:800)
> > at
ter.java:429)
> > at
222)
> > at
> > !MESSAGE Bundle
initial@reference:file:c:/eclipse-SDK-3.0.1-win32/eclipse/plugins/org.eclips
e.core.runtime_3.0.1/
Re: newbie needs urgent help please [message #28649 is a reply to message #28616] Mon, 21 February 2005 16:45 Go to previous messageGo to next message
I have installed j2sdk-1-4-2 so I do not think that's the problem. The
same java SDK is what I was using before and every thing was working well.
Where in the registry(or eclipse config file) can I change the path of the
JV running Eclipse?. I really need this going. This might be the problem.
ANY HELP will be highly appreciated.
Re: newbie needs urgent help please [message #28651 is a reply to message #28649] Mon, 21 February 2005 16:59 Go to previous messageGo to next message
Use the -vm option when starting Eclipse to point to the 1.4.2 install you
have
HTH
Darins
news:cvdkp6$6gb$1@www.eclipse.org...
Re: newbie needs urgent help please [message #28653 is a reply to message #28616] Mon, 21 February 2005 17:07 Go to previous messageGo to next message
I have j2sdk1-4-2 installed. I do not think that is the real problem here.
What I think is that the initial VM path has been changed by the programms
I later on installed. How can I change the VM path to
c:j2sdk1-4-2\bin\javaw ?. I think this might be the issue here. Could any
one tell me how to change this?
Re: newbie needs urgent help please [message #28655 is a reply to message #28616] Mon, 21 February 2005 17:07 Go to previous messageGo to next message
Re: newbie needs urgent help please [message #28668 is a reply to message #28655] Mon, 21 February 2005 18:01 Go to previous messageGo to next message
> c:j2sdk1-4-2binjavaw ?. I think this might be the issue here. Could any
THE PROBLEM HAS BEEN SOLVED.I DID THE FOLLOWING: I edited the Path
variables to point to c:\j2sdk1-4-2.( right click on my
computer-->properties-->under Advance in WIN XP and click on Environment
virables.--> Click edit and change the path to point ot your java path.
Click ok and start up eclipse again.) Every thing went well.
Re: newbie needs urgent help please [message #28672 is a reply to message #28668] Mon, 21 February 2005 18:08 Go to previous message
Until the next time some other software installer changes your path
variable...
Darins
news:cvdp8m$p03$1@www.eclipse.org...
>> here. What I think is that the initial VM path has been changed by the
>> programms I later on installed. How can I change the VM path to
Previous Topic:Eclipse startup problem.
Next Topic:Tomcat 5.5.6
Current Time: Tue Aug 12 16:01:08 EDT 2025
Powered by FUDForum. Page generated in 0.11043 seconds
