Home » Archived » DSDP - Real-Time Software Components (RTSC) » pb running some commands in lesson 2 of packaging primer
pb running some commands in lesson 2 of packaging primer [message #2432] Tue, 05 May 2009 08:47 Go to next message
I ran lesson 2 from the packaging primer and the command
xs xdc.tools.repoman -c -v -r «local»/myrepo -p
«shared»/products/charlie_mathsu.../packages charlie.*
did not work (no match).
I could nevertheless copy each package individually i.e.
«shared»/products/charlie_mathsu.../packages charlie.sqrtlib
and
«shared»/products/charlie_mathsu.../packages charlie.sqrtlib.samples
I am using using xdctools_3_15_00_33 on linux.
Re: pb running some commands in lesson 2 of packaging primer [message #2523 is a reply to message #2432] Wed, 06 May 2009 10:10 Go to previous messageGo to next message
You need to put charlie.* in quotes on the command line; otherwise, the
shell tries to expand charlie.* and will not find anything in the
current working directory and report "(no match)".
> and
Re: pb running some commands in lesson 2 of packaging primer [message #2553 is a reply to message #2523] Wed, 06 May 2009 10:20 Go to previous message
Ok thanks.
Previous Topic:typedefs in the RTSC spec world
Next Topic:using specific version of gcc
Current Time: Fri Jul 04 14:04:41 EDT 2025
Powered by FUDForum. Page generated in 0.20945 seconds
