Home » Language IDEs » Java Development Tools (JDT) » Eclipse Ant compiler options
Eclipse Ant compiler options [message #2431] Wed, 23 April 2003 11:08 Go to next message
Originally posted by: scottresnik.hotmail.com
Hello:
I'm using the eclipse ant compiler(org.eclipse.jdt.core.JDTCompilerAdapter),
and I was wondering if there was a way to make that compiler use all the
same settings that I have configured in the Eclipse IDE
(under Window->Preferences->Java->Compiler).
Basically what is happening, is that my project compiles fine, but when I
run ant, I'm getting warning about unused imports and such, I have those
warnings disabled in eclipse, but ant isn't recognizing them when I run ant
through eclipse. Any ideas?
Re: Eclipse Ant compiler options [message #2636 is a reply to message #2431] Wed, 23 April 2003 12:43 Go to previous messageGo to next message
Originally posted by: Olivier_Thomann.ca.ibm.comNOSPAM
On Wed, 23 Apr 2003 10:08:32 -0500, "Scott Resnik"
This is under investigation.
http://bugs.eclipse.org/bugs/show_bug.cgi?id=25510
The current issue are when the ant task is not running on the same VM
and getting the project's settings instead of the global settings.
Olivier
Re: Eclipse Ant compiler options [message #2693 is a reply to message #2636] Wed, 23 April 2003 13:48 Go to previous messageGo to next message
Well, how bout this then, can I just replicate the same settings that I have
in the compiler preferences screen in a seperate properites file, or command
line options. Is there a source for the full complement of command line
arguments, and properties that can be set on the eclipse compiler? To me
having all that that would be just as effective as ant getting the IDE's
compiler settings.
Scott
"Olivier Thomann" <Olivier_Thomann@ca.ibm.comNOSPAM> wrote in message
news:6jgdavspd5k5eeeocjo8oai10jt5e20iib@4ax.com...
ant
> Olivier
Re: Eclipse Ant compiler options [message #2713 is a reply to message #2693] Wed, 23 April 2003 13:59 Go to previous messageGo to next message
On Wed, 23 Apr 2003 12:48:34 -0500, "Scott Resnik"
>compiler settings.
You can patch the source. This is trivial. But using a property file
can be a good idea as long as we don't have a good solution for ant
scripts that run on a separate VM.
I will investigate it.
Olivier
Re: Eclipse Ant compiler options [message #3749 is a reply to message #2713] Wed, 23 April 2003 14:03 Go to previous message
FYI we are working hard to get integrated support for Ant optionally on a
separate VM coming soon...
http://bugs.eclipse.org/bugs/show_bug.cgi?id=24129
Darins
news:l2ldavothchqmsal07o4u2hmlavkjcfss1@4ax.com...
have
command
> >compiler settings.
> Olivier
Previous Topic:Actions to View communication
Next Topic:How to limit number of projects showing up in navigator?
Current Time: Sun Jul 27 01:28:57 EDT 2025
Powered by FUDForum. Page generated in 0.04752 seconds
