Home » Eclipse Projects » Eclipse Platform » No BUNDLE_CLASSPATH for org.eclipse.osgi
No BUNDLE_CLASSPATH for org.eclipse.osgi [message #283935] Thu, 14 April 2005 04:44 Go to next message
Originally posted by: scheglov_ke.nlmk.ru
I ask for plugin classpath using this code:
org.osgi.framework.Bundle bundle = Platform.getBundle(pluginId);
String requires = (String)
bundle.getHeaders().get(org.osgi.framework.Constants.BUNDLE_ CLASSPATH);
org.eclipse.osgi.util.ManifestElement[] elements =
org.eclipse.osgi.util.ManifestElement.parseHeader(org.osgi.f ramework.Constants.BUNDLE_CLASSPATH,
requires);
This works for all plugins except org.eclipse.osgi - there are no
such header. Is it bug or such feature?
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: No BUNDLE_CLASSPATH for org.eclipse.osgi [message #283940 is a reply to message #283935] Thu, 14 April 2005 07:58 Go to previous messageGo to next message
--------------000702040806000508060204
Content-Type: text/plain; charset=KOI8-R; format=flowed
Konstantin,
We've run into this kind of problem too and have had to do some
significant restructuring to accommodate the changes in behavior. Below
is a method we've put in org.eclipse.emf.codegen.CodeGen to centralize
the processing. Note that when we get back a null, we treat it as being
the same as ".". Also note that later, trying to get a bundle entry for
".", which may appear literally in the manifest, we treat it the same
as "/", which isn't really quite the same thing; getting a bundle entry
for "." will return null. And finally, we do some special processing
to be sure we get the jar for the whole plugin, rather than the root
entry within that jar.
public static List getClasspathPaths(String pluginID) throws
JETException
List result = new ArrayList();
try
Bundle bundle = Platform.getBundle(pluginID);
String requires =
(String)bundle.getHeaders().get(Constants.BUNDLE_CLASSPATH);
if (requires == null)
requires = ".";
ManifestElement.parseHeader(Constants.BUNDLE_CLASSPATH, requires);
if (elements != null)
for (int i = 0, count = 0; i < elements.length; ++i)
ManifestElement element = elements[i];
String value = element.getValue();
if (".".equals(value))
value = "/";
try
URL url = bundle.getEntry(value);
if (url != null)
URL resolvedURL = Platform.resolve(url);
String resolvedURLString = resolvedURL.toString();
if (resolvedURLString.endsWith("!/"))
resolvedURLString = resolvedURL.getFile();
resolvedURLString =
resolvedURLString.substring(0,resolvedURLString.length() -
"!/".length());
if (resolvedURLString.startsWith("file:"))
result.add(resolvedURLString.substring("file:".length()));
else
result.add(Platform.asLocalURL(url).getFile());
catch (IOException exception)
throw new JETException(exception);
break;
catch (BundleException exception)
return result;
> requires);
Content-Type: text/html; charset=KOI8-R
<html>
<head>
<meta content="text/html;charset=KOI8-R" http-equiv="Content-Type">
</head>
Konstantin,<br>
<br>
Re: No BUNDLE_CLASSPATH for org.eclipse.osgi [message #283948 is a reply to message #283940] Thu, 14 April 2005 08:46 Go to previous message
Ed Merks:
Thank you.
> JETException
> try
> String requires =
> requires = ".";
> value = "/";
> try
> if (url != null)
> resolvedURLString =
> "!/".length());
> else
> break;
> return result;
>> requires);
SY, Konstantin.
Previous Topic:PDE Build: pde.build.scripts isn't affective
Next Topic:SWT event post
Current Time: Wed Jul 23 12:01:51 EDT 2025
Powered by FUDForum. Page generated in 0.11497 seconds
