Home » Archived » Visual Editor (VE) » Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite?
Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #2400] Thu, 20 November 2003 08:14 Go to next message
Originally posted by: use.reply.to.invalid
I would like to try out VE, but is somewhat taken back by Eclipse 2.1.2
listed as a prerequisite.
Does the provided code run as well under 3.0M4 which I use on a daily basis?
Thorbjoern Ravn Andersen "...plus...Tubular Bells!"
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #2430 is a reply to message #2400] Thu, 20 November 2003 10:12 Go to previous messageGo to next message
Thorbjoern,
As Dave Orme (VE project lead) mentioned in the eclipse.platform newsgroup:
"The 1.0 version will support 3.0. We're an Eclipse project now so we're
merging our development cycle with Eclipse's. But that will be a
process that won't happen overnight."
This is our next release.
Regards...
Peter Walker
"Thorbj
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #2459 is a reply to message #2400] Thu, 20 November 2003 10:17 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
0.5.0 will shortly be a release. Releases need to run on released
pre-reqs. 3.0M4 is still not a release, so we didn't want to pre-req it.
The current Eclipse release is 2.1.2. So that is why it is for 2.1.2.
And unfortunately, no it won't run on 3.0M4 because there have been
significant changes in parts of the base Eclipse code that causes the
editor to not work. The 1.0.0 development stream will eventually step up
to 3.0, but that won't be for a little while yet. There will be a major
API breaking change in 3.0 being released with 3.0M5, and we don't want
to spend our time doing two migrations. We only want to do it once.
We also have some important things we want to work on, like fixing some
of the larger performance problems and we want a stable platform for that.
Thanks, Rich Kulp
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #2669 is a reply to message #2459] Thu, 20 November 2003 22:50 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
Unless you like answering this question a *lot*, I strongly suggest you move
up to 3.0M* as soon as possible. The CDT project is doing that next week I
believe. Ideally, a project's HEAD would work with Platform's HEAD.
Ed Burnette, co-author, Eclipse in Action
www.eclipsepowered.org
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:bpilq9$b2q$1@eclipse.org...
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #3820 is a reply to message #2430] Fri, 21 November 2003 11:47 Go to previous messageGo to next message
Peter Walker wrote:
> Thorbjoern,
> Regards...
> Peter Walker
Thank you for the response and the pointer. I'll just sit on my hands
for a while then :)
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #3827 is a reply to message #2669] Fri, 21 November 2003 12:21 Go to previous messageGo to next message
The reasons for waiting to support 3.0M* seem sound, but since M4 is works
so darn well - I agree this will come up a great deal.
At a minium I recommend plastering the FAQ, and the Download page of VEP
with a note that it won't work with 3.0M* for a bit...
-bob
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #5558 is a reply to message #3827] Tue, 25 November 2003 21:41 Go to previous messageGo to next message
> Cheers,
> -bob
Thanks! I think I'll do just that.
Dave
Dave Orme
Eclipse Visual Editor Project Lead
Advanced Systems Concepts' Chief Architect
http://www.swtworkbench.com
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #5621 is a reply to message #5558] Wed, 26 November 2003 16:41 Go to previous messageGo to next message
In article <bq13vi$12s$1@eclipse.org>,
> > Cheers,
> > -bob
I would also add an estimated date for that. It does not have to be
screamingly accurate, but it would be good to know whether the
synchronization with recent M builds is something I should look for in
December, or in Q32004.
It looks quite spiffy, and was one of the missing pieces for my own GUI
development. Congrats!
(BTW, I use MacOS X, so please do qualify it there.)
Scott
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #6515 is a reply to message #2669] Sun, 30 November 2003 09:31 Go to previous messageGo to next message
Why not make a version that can be dropped into 2.1.x series
and then completey merge the code base into the base of eclipse it self?
This kind of thing needs to be in the base. Not as a add on that won't
keep up directly with the latest release of the main..
johan
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #8084 is a reply to message #2430] Wed, 03 December 2003 16:46 Go to previous messageGo to next message
Originally posted by: david.eclipsecat.com
Anyway to import Netbeans files into the visual editor and have them
come out looking right?
Peter Walker wrote:
> Thorbjoern,
> Regards...
> Peter Walker
> "Thorbjørn Ravn Andersen" <use@reply.to.invalid> wrote in message
> news:bpiej0$o6$1@eclipse.org...
> basis?
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #8145 is a reply to message #8084] Thu, 04 December 2003 09:03 Go to previous messageGo to next message
This is not officially supported and I haven't tried this yet... not sure
what the code looks like that comes out of Netbeans. If the code patterns
are such that each AWT/Swing component is declared in the class and has a
method that initializes it (i.e. jButton = new JButton()), it should work.
Please feel free to try it and report your results.
Thanks...
Peter walker
"David Siebert" <david@eclipsecat.com> wrote in message
news:bqllem$8ij$2@eclipse.org...
> Peter Walker wrote:
> > Thorbjoern,
newsgroup:
we're
> > Regards...
> > Peter Walker
> > "Thorbj
VE importing NetBeans [message #8208 is a reply to message #8145] Thu, 04 December 2003 10:28 Go to previous messageGo to next message
I did try it and it looks a little odd. Actually I tried it before I posted.
What is odd is that it looks like all of the elements are there but they
are not put together. I do not know it that is the way that VE supposed
to look or not. I just got Eclipse working and I am considering using it
instead of NetBeans. Net Beans has been very good to me but it is a
little slow.
> Thanks...
> Peter walker
>>Peter Walker wrote:
>>>Thorbjoern,
> newsgroup:
> we're
>>>Regards...
>>>Peter Walker
>>>basis?
Re: VE importing NetBeans [message #8277 is a reply to message #8208] Thu, 04 December 2003 12:47 Go to previous messageGo to next message
Originally posted by: mendelgili.netscape.net
--------------090206010809080200010505
> posted.
JVE has a default "getter" code pattern that will get more flexible as
we move forward. One can extend it (see pref. attachement)
If you provide a small src. code that you are trying to load JVE with,
and is not rendered the same as when it is run we can try and help you
understand the patterns differences.
> little slow.
>> work.
>> Thanks...
>> Peter walker
>>> Peter Walker wrote:
>>>> Thorbjoern,
>> newsgroup:
>> we're
>>>> Regards...
>>>> Peter Walker
>>>> "Thorbj
Re: VE importing NetBeans [message #8340 is a reply to message #8277] Thu, 04 December 2003 14:50 Go to previous messageGo to next message
--------------080300090806020007010700
Content-Type: text/plain; charset=us-ascii; format=flowed
Here is the file I tried to export.
So far I find Eclipse to be pretty good. The Perl plugin seems to work
well. VE seems like it is a pretty nice piece of work but I have only
really just started to play with Eclipse. I have added two new features
to one of my programs today so I would say I am off to a good start.
name="AddCallDLG.java"
Content-Disposition: inline;
filename="AddCallDLG.java"
* AddCallDLG.java
* Created on July 16, 2001, 1:57 PM
* @author david
* @version
/* Todo
* Make it so you pass a Phone call to the dialog and it fills it in fo you.
import javax.swing.JComboBox;
import java.util.ArrayList;
public class AddCallDLG extends javax.swing.JDialog {
private ErrorLogging m_oErrLog;
private int i_switch=0;
String m_sAccountNO;
private String m_phone, m_phone2;
boolean m_bOkay=false;
private boolean m_bfcall=false;
javax.swing.JList m_oCallList;
private PhoneCall m_oPhoneCall;
private MyDataBase m_oDB;
/** Creates new form AddCallDLG */
public AddCallDLG(PhoneMainFrame parent,boolean modal,PhoneCall p_phone,ErrorLogging errorlog) {
super(parent, modal);
//PhoneMainFrame mf = (PhoneMainFrame) parent;
m_oDB=parent.o_SqlConnection;
m_oErrLog=errorlog;
m_oPhoneCall=p_phone;
initComponents();
pack();
public int getStatusData(String name){
int retval=0;
try{
java.sql.Statement stmt = m_oDB.m_sqlConnection.createStatement();
java.sql.ResultSet rs = stmt.executeQuery("Select * FROM phonegroups WHERE pgroup = '"+name+"'");
PhoneUser t_phoneuser=null;
//create an ArrayList of PhoneCalls
if (rs.next()){
retval=1;
else {
rs = stmt.executeQuery("Select * FROM phoneusers WHERE username= '"+name+"'");
if (rs.next()){
t_phoneuser = new PhoneUser(m_oDB,rs);
retval=t_phoneuser.getUserStatus();
} catch (Exception ex){
// TODO Add more errorchecking code here.
System.err.println(ex.toString());
return retval;
/** This method is called from within the constructor to
* initialize the form.
* WARNING: Do NOT modify this code. The content of this method is
* always regenerated by the FormEditor.
private void initComponents() {//GEN-BEGIN:initComponents
java.awt.GridBagConstraints gridBagConstraints;
jLabel1 = new javax.swing.JLabel();
jLabel2 = new javax.swing.JLabel();
jLabel3 = new javax.swing.JLabel();
jLabel4 = new javax.swing.JLabel();
jLabel5 = new javax.swing.JLabel();
nameJTextField = new javax.swing.JTextField();
phoneJTextField = new javax.swing.JTextField();
phone2JTextField = new javax.swing.JTextField();
statusjComboBox = new javax.swing.JComboBox();
jTextFieldNotes = new javax.swing.JTextField();
jButtonOk = new javax.swing.JButton();
cancle = new javax.swing.JButton();
prijLabel = new javax.swing.JLabel();
priComboBox = new javax.swing.JComboBox();
forjLabel = new javax.swing.JLabel();
jComboBoxFor = new javax.swing.JComboBox();
jButtionJSwitch = new javax.swing.JButton();
getContentPane().setLayout(new java.awt.GridBagLayout());
setTitle("Add a Call");
addComponentListener(new java.awt.event.ComponentAdapter() {
public void componentShown(java.awt.event.ComponentEvent evt) {
formComponentShown(evt);
addWindowListener(new java.awt.event.WindowAdapter() {
public void windowClosing(java.awt.event.WindowEvent evt) {
closeDialog(evt);
jLabel1.setDisplayedMnemonic('N');
jLabel1.setFont(new java.awt.Font("Dialog", 0, 14));
jLabel1.setLabelFor(nameJTextField);
jLabel1.setText("Name");
gridBagConstraints = new java.awt.GridBagConstraints();
gridBagConstraints.gridx = 0;
gridBagConstraints.gridy = 0;
gridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
gridBagConstraints.insets = new java.awt.Insets(0, 3, 0, 0);
getContentPane().add(jLabel1, gridBagConstraints);
jLabel2.setDisplayedMnemonic('P');
jLabel2.setFont(new java.awt.Font("Dialog", 0, 14));
jLabel2.setLabelFor(phoneJTextField);
jLabel2.setText("Phone");
gridBagConstraints.gridy = 1;
getContentPane().add(jLabel2, gridBagConstraints);
jLabel3.setDisplayedMnemonic('2');
jLabel3.setFont(new java.awt.Font("Dialog", 0, 14));
jLabel3.setLabelFor(phone2JTextField);
jLabel3.setText("Phone2");
gridBagConstraints.gridy = 2;
getContentPane().add(jLabel3, gridBagConstraints);
jLabel4.setDisplayedMnemonic('a');
jLabel4.setFont(new java.awt.Font("Dialog", 0, 14));
jLabel4.setLabelFor(statusjComboBox);
jLabel4.setText("Status");
gridBagConstraints.gridy = 3;
getContentPane().add(jLabel4, gridBagConstraints);
jLabel5.setDisplayedMnemonic('t');
jLabel5.setFont(new java.awt.Font("Dialog", 0, 14));
jLabel5.setLabelFor(jTextFieldNotes);
jLabel5.setText("Note");
gridBagConstraints.gridy = 5;
getContentPane().add(jLabel5, gridBagConstraints);
nameJTextField.addFocusListener(new java.awt.event.FocusAdapter() {
public void focusGained(java.awt.event.FocusEvent evt) {
nameJTextFieldFocusGained(evt);
nameJTextField.addKeyListener(new java.awt.event.KeyAdapter() {
public void keyTyped(java.awt.event.KeyEvent evt) {
nameJTextFieldKeyTyped(evt);
gridBagConstraints.gridx = 1;
gridBagConstraints.gridwidth = 5;
gridBagConstraints.ipadx = 396;
gridBagConstraints.ipady = 10;
gridBagConstraints.insets = new java.awt.Insets(0, 10, 0, 3);
getContentPane().add(nameJTextField, gridBagConstraints);
phoneJTextField.addFocusListener(new java.awt.event.FocusAdapter() {
phoneJTextFieldFocusGained(evt);
phoneJTextField.addKeyListener(new java.awt.event.KeyAdapter() {
phoneJTextFieldKeyTyped(evt);
gridBagConstraints.gridwidth = 4;
gridBagConstraints.insets = new java.awt.Insets(0, 10, 0, 0);
getContentPane().add(phoneJTextField, gridBagConstraints);
phone2JTextField.addFocusListener(new java.awt.event.FocusAdapter() {
phone2JTextFieldFocusGained(evt);
phone2JTextField.addKeyListener(new java.awt.event.KeyAdapter() {
phone2JTextFieldKeyTyped(evt);
getContentPane().add(phone2JTextField, gridBagConstraints);
statusjComboBox.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(java.awt.event.ActionEvent evt) {
statusjComboBoxActionPerformed(evt);
statusjComboBox.addMouseWheelListener(new java.awt.event.MouseWheelListener() {
public void mouseWheelMoved(java.awt.event.MouseWheelEvent evt) {
statusjComboBoxMouseWheelMoved(evt);
getContentPane().add(statusjComboBox, gridBagConstraints);
jTextFieldNotes.addFocusListener(new java.awt.event.FocusAdapter() {
jTextFieldNotesFocusGained(evt);
jTextFieldNotes.addKeyListener(new java.awt.event.KeyAdapter() {
jTextFieldNotesKeyTyped(evt);
gridBagConstraints.ipadx = 500;
getContentPane().add(jTextFieldNotes, gridBagConstraints);
jButtonOk.setMnemonic('O');
jButtonOk.setText("Ok");
jButtonOk.setSelected(true);
jButtonOk.addActionListener(new java.awt.event.ActionListener() {
jButtonOkActionPerformed(evt);
gridBagConstraints.gridy = 6;
getContentPane().add(jButtonOk, gridBagConstraints);
cancle.setMnemonic('C');
cancle.setText("Cancel");
cancle.addActionListener(new java.awt.event.ActionListener() {
cancleActionPerformed(evt);
gridBagConstraints.gridx = 5;
gridBagConstraints.fill = java.awt.GridBagConstraints.VERTICAL;
gridBagConstraints.anchor = java.awt.GridBagConstraints.EAST;
gridBagConstraints.insets = new java.awt.Insets(0, 0, 0, 3);
getContentPane().add(cancle, gridBagConstraints);
prijLabel.setDisplayedMnemonic('r');
prijLabel.setFont(new java.awt.Font("Dialog", 0, 14));
prijLabel.setLabelFor(priComboBox);
prijLabel.setText("Priority ");
prijLabel.setName("Add Call");
gridBagConstraints.gridx = 2;
gridBagConstraints.gridwidth = 2;
getContentPane().add(prijLabel, gridBagConstraints);
priComboBox.addMouseWheelListener(new java.awt.event.MouseWheelListener() {
priComboBoxMouseWheelMoved(evt);
gridBagConstraints.gridx = 4;
getContentPane().add(priComboBox, gridBagConstraints);
forjLabel.setDisplayedMnemonic('F');
forjLabel.setFont(new java.awt.Font("Dialog", 0, 14));
forjLabel.setLabelFor(jComboBoxFor);
forjLabel.setText("For");
gridBagConstraints.gridy = 4;
getContentPane().add(forjLabel, gridBagConstraints);
jComboBoxFor.addMouseListener(new java.awt.event.MouseAdapter() {
public void mouseReleased(java.awt.event.MouseEvent evt) {
jComboBoxForMouseReleased(evt);
jComboBoxFor.addMouseWheelListener(new java.awt.event.MouseWheelListener() {
jComboBoxForMouseWheelMoved(evt);
jComboBoxFor.addPropertyChangeListener(new java.beans.PropertyChangeListener() {
public void propertyChange(java.beans.PropertyChangeEvent evt) {
jComboBoxForPropertyChange(evt);
gridBagConstraints.ipadx = 260;
gridBagConstraints.ipady = 5;
getContentPane().add(jComboBoxFor, gridBagConstraints);
jButtionJSwitch.setMnemonic('S');
jButtionJSwitch.setText("Switch");
jButtionJSwitch.addActionListener(new java.awt.event.ActionListener() {
jButtionJSwitchActionPerformed(evt);
gridBagConstraints.gridheight = 2;
gridBagConstraints.fill = java.awt.GridBagConstraints.HORIZONTAL;
getContentPane().add(jButtionJSwitch, gridBagConstraints);
}//GEN-END:initComponents
private void jTextFieldNotesFocusGained(java.awt.event.FocusEvent evt) {//GEN-FIRST:event_jTextFieldNotesFocusGained
// Add your handling code here:
if(this.m_bfcall){
this.jTextFieldNotes.setCaretPosition(this.jTextFieldNotes.g etText().length());
} else this.setSelectTextAll(this.jTextFieldNotes);
}//GEN-LAST:event_jTextFieldNotesFocusGained
private void phone2JTextFieldFocusGained(java.awt.event.FocusEvent evt) {//GEN-FIRST:event_phone2JTextFieldFocusGained
this.setSelectTextAll(this.phone2JTextField);
}//GEN-LAST:event_phone2JTextFieldFocusGained
private void nameJTextFieldFocusGained(java.awt.event.FocusEvent evt) {//GEN-FIRST:event_nameJTextFieldFocusGained
this.setSelectTextAll(this.nameJTextField);
}//GEN-LAST:event_nameJTextFieldFocusGained
private void phoneJTextFieldFocusGained(java.awt.event.FocusEvent evt) {//GEN-FIRST:event_phoneJTextFieldFocusGained
this.setSelectTextAll(this.phoneJTextField);
}//GEN-LAST:event_phoneJTextFieldFocusGained
private static void setSelectTextAll(javax.swing.JTextField textField){
textField.setSelectionStart(0);
textField.setSelectionEnd(textField.getText().length());
private void jComboBoxForMouseWheelMoved(java.awt.event.MouseWheelEvent evt) {//GEN-FIRST:event_jComboBoxForMouseWheelMoved
this.scrollWheelComboBox(evt, this.jComboBoxFor);
}//GEN-LAST:event_jComboBoxForMouseWheelMoved
private void statusjComboBoxMouseWheelMoved(java.awt.event.MouseWheelEven t evt) {//GEN-FIRST:event_statusjComboBoxMouseWheelMoved
this.scrollWheelComboBox(evt, this.statusjComboBox);
}//GEN-LAST:event_statusjComboBoxMouseWheelMoved
private void scrollWheelComboBox(java.awt.event.MouseWheelEvent evt, javax.swing.JComboBox cBox){
int i_inc = +1;
if(evt.getWheelRotation()<0) {i_inc=-1;}
int pos=cBox.getSelectedIndex()+i_inc;
if(pos>=cBox.getItemCount()) pos=0;
if(pos<0) pos=cBox.getItemCount()-1;
cBox.setSelectedIndex(pos);
private void priComboBoxMouseWheelMoved(java.awt.event.MouseWheelEvent evt) {//GEN-FIRST:event_priComboBoxMouseWheelMoved
this.scrollWheelComboBox(evt, this.priComboBox);
}//GEN-LAST:event_priComboBoxMouseWheelMoved
private void jComboBoxForMouseReleased(java.awt.event.MouseEvent evt) {//GEN-FIRST:event_jComboBoxForMouseReleased
String user =(String)this.jComboBoxFor.getSelectedItem();
if (user!=null) if (getStatusData(user)==0){
System.err.println("not On Phone");
}//GEN-LAST:event_jComboBoxForMouseReleased
private void jComboBoxForPropertyChange(java.beans.PropertyChangeEvent evt) {//GEN-FIRST:event_jComboBoxForPropertyChange
new NotHereDLG(new javax.swing.JFrame(), true,user).show();
}//GEN-LAST:event_jComboBoxForPropertyChange
private void formComponentShown(java.awt.event.ComponentEvent evt) {//GEN-FIRST:event_formComponentShown
checkTextFieldLen(jTextFieldNotes,3998);
checkTextFieldLen(phone2JTextField,39);
checkTextFieldLen(phoneJTextField,39);
checkTextFieldLen(nameJTextField,79);
if(this.m_bfcall){
this.priComboBox.setSelectedIndex(1);
javax.swing.JOptionPane.showMessageDialog(this,"First Call");
}//GEN-LAST:event_formComponentShown
private void jTextFieldNotesKeyTyped(java.awt.event.KeyEvent evt) {//GEN-FIRST:event_jTextFieldNotesKeyTyped
}//GEN-LAST:event_jTextFieldNotesKeyTyped
private void phone2JTextFieldKeyTyped(java.awt.event.KeyEvent evt) {//GEN-FIRST:event_phone2JTextFieldKeyTyped
}//GEN-LAST:event_phone2JTextFieldKeyTyped
private void phoneJTextFieldKeyTyped(java.awt.event.KeyEvent evt) {//GEN-FIRST:event_phoneJTextFieldKeyTyped
}//GEN-LAST:event_phoneJTextFieldKeyTyped
private void nameJTextFieldKeyTyped(java.awt.event.KeyEvent evt) {//GEN-FIRST:event_nameJTextFieldKeyTyped
}//GEN-LAST:event_nameJTextFieldKeyTyped
private void jButtionJSwitchActionPerformed(java.awt.event.ActionEvent evt) {//GEN-FIRST:event_jButtionJSwitchActionPerformed
switch(i_switch){
case 0:
i_switch++;
phoneJTextField.setText(m_phone2);
phone2JTextField.setText(m_phone);
break;
case 1:
i_switch++;
phoneJTextField.setText("");
phoneJTextField.requestFocus();
break;
default :
i_switch=0;
phoneJTextField.setText(m_phone);
phone2JTextField.setText(m_phone2);
}//GEN-LAST:event_jButtionJSwitchActionPerformed
private void checkTextFieldLen(javax.swing.JTextField f, int size){
String text= f.getText();
if(text.length()>size){
text=text.substring(0,size);
f.setText(text);
private void cancleActionPerformed(java.awt.event.ActionEvent evt) {//GEN-FIRST:event_cancleActionPerformed
setVisible(false);
dispose();
}//GEN-LAST:event_cancleActionPerformed
private void jButtonOkActionPerformed(java.awt.event.ActionEvent evt) {//GEN-FIRST:event_jButtonOkActionPerformed
this.m_bOkay=true;
m_oPhoneCall.setPhoneCall( nameJTextField.getText(), phoneJTextField.getText(), phone2JTextField.getText(),"", jComboBoxFor.getSelectedItem().toString() ,jTextFieldNotes.getText(),priComboBox.getSelectedItem().toS tring(),statusjComboBox.getSelectedItem().toString(),m_oDB);
setVisible(false);
}//GEN-LAST:event_jButtonOkActionPerformed
private void statusjComboBoxActionPerformed(java.awt.event.ActionEvent evt) {//GEN-FIRST:event_statusjComboBoxActionPerformed
}//GEN-LAST:event_statusjComboBoxActionPerformed
/** Closes the dialog */
private void closeDialog(java.awt.event.WindowEvent evt) {//GEN-FIRST:event_closeDialog
setVisible(false);
dispose();
}//GEN-LAST:event_closeDialog
* @param args the command line arguments
public static void main(String args[]) {
//new AddCallDLG (new javax.swing.JFrame (), true).show ();
public void setPriList(String [] p_saList) {
for(int i=0;i<p_saList.length;i++){
this.priComboBox.addItem(makeObj(p_saList[i]));
public void setStatusList(String [] p_saList) {
this.statusjComboBox.addItem(makeObj(p_saList[i]));
public void setCallerListName(String name){
int inx=this.jComboBoxFor.getItemCount()-1;
while (inx>0 && ((String)this.jComboBoxFor.getItemAt(inx)).equalsIgnoreCase( name)== false){
inx--;
this.jComboBoxFor.setSelectedIndex(inx);
public void setCallerList(ArrayList p_saList) {
for(int i=0;i<p_saList.size();i++){
this.jComboBoxFor.addItem(p_saList.get(i));
public PhoneCall getPhoneCall(){
//public PhoneCall(String p_sCaller, String p_sPhone, String p_sPhone2, String p_sQedBy, String p_sFor, String p_sNotes, String p_sPri,String p_sStatus)
PhoneCall pcall= new PhoneCall(nameJTextField.getText(),phoneJTextField.getText() ,phone2JTextField.getText(), "",(String)jComboBoxFor.getSelectedItem(), jTextFieldNotes.getText(),(String)priComboBox.getSelectedIte m(),(String)statusjComboBox.getSelectedItem(),m_oErrLog,m_oD B);
return (pcall);
public PhoneCall getPhoneCall(String UserID){
PhoneCall pcall= new PhoneCall(nameJTextField.getText(),phoneJTextField.getText() ,phone2JTextField.getText(),UserID,(String)jComboBoxFor.getS electedItem(), jTextFieldNotes.getText(),(String)priComboBox.getSelectedIte m(),(String)statusjComboBox.getSelectedItem(),m_oErrLog,m_oD B);
return (pcall);
private Object makeObj(final String item) {
return new Object() { public String toString() { return item; } };
public void setCustInfo(String name, String phone, String phone2, String accountno){
nameJTextField.setText(name);
phoneJTextField.setText(phone);
m_phone=phone;
phone2JTextField.setText(phone2);
m_phone2=phone2;
this.m_sAccountNO=accountno;
if(this.m_oPhoneCall.isFirstCall(m_oDB,name)){
System.err.println("FirstCall");
this.jTextFieldNotes.setText("First Call:");
this.m_bfcall=true;
} else System.err.println("not F call");
public void setCallList(javax.swing.JList p_list){
m_oCallList=p_list;
// Variables declaration - do not modify//GEN-BEGIN:variables
private javax.swing.JLabel jLabel4;
private javax.swing.JTextField phone2JTextField;
private javax.swing.JLabel jLabel1;
private javax.swing.JLabel jLabel3;
private javax.swing.JTextField phoneJTextField;
private javax.swing.JLabel jLabel2;
private javax.swing.JLabel prijLabel;
private javax.swing.JComboBox statusjComboBox;
private javax.swing.JButton cancle;
private javax.swing.JTextField jTextFieldNotes;
private javax.swing.JButton jButtonOk;
private javax.swing.JTextField nameJTextField;
private javax.swing.JButton jButtionJSwitch;
private javax.swing.JComboBox priComboBox;
private javax.swing.JComboBox jComboBoxFor;
private javax.swing.JLabel forjLabel;
private javax.swing.JLabel jLabel5;
// End of variables declaration//GEN-END:variables
--------------080300090806020007010700--
Re: VE importing NetBeans [message #8516 is a reply to message #8340] Fri, 05 December 2003 08:54 Go to previous messageGo to next message
--------------010807050909080305090803
There are two pattern issues that inhibits VE to parse this code properly:
1. implicit content pane. VE requires (in this version) to explicitly
declare a content pane.
2. When using GridBag constraints, you will have to declare a unique
constraint for each component you are adding ... the code above reuse
the same variable (yet still allocate a new one).
I modified the code by hand, so that you can diff the files. Note that
there are many compile errors in the file, as this code reference
classes that are not available. The beauty of VE is that compile errors
that are not relevant are ignored.
> * AddCallDLG.java
> * @author david
> * @version
> /* Todo
> m_oErrLog=errorlog;
> initComponents();
> pack();
> int retval=0;
> try{
> if (rs.next()){
> retval=1;
> else {
> if (rs.next()){
> return retval;
> closeDialog(evt);
> if(this.m_bfcall){
> int i_inc = +1;
> if(this.m_bfcall){
> switch(i_switch){
> case 0:
> i_switch++;
> break;
> case 1:
> i_switch++;
> break;
> default :
> i_switch=0;
> f.setText(text);
> setVisible(false);
> dispose();
> this.m_bOkay=true;
> setVisible(false);
> setVisible(false);
> dispose();
> inx--;
> return (pcall);
> return (pcall);
> m_phone=phone;
> m_phone2=phone2;
> this.m_bfcall=true;
> m_oCallList=p_list;
Content-Type: text/java;
* AddCallDLG.java
* @author david
* @version
/* Todo
m_oErrLog=errorlog;
initComponents();
pack();
int retval=0;
try{
if (rs.next()){
retval=1;
else {
if (rs.next()){
return retval;
// java.awt.GridBagConstraints gridBagConstraints; VE requires distinct constraints
jDialogContentPane = new javax.swing.JPanel() ; // Explicit content pane
setContentPane(jDialogContentPane);
jDialogContentPane.setLayout(new java.awt.GridBagLayout());
closeDialog(evt);
java.awt.GridBagConstraints l1gridBagConstraints = new java.awt.GridBagConstraints();
l1gridBagConstraints.gridx = 0;
l1gridBagConstraints.gridy = 0;
l1gridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
l1gridBagConstraints.insets = new java.awt.Insets(0, 3, 0, 0);
jDialogContentPane.add(jLabel1, l1gridBagConstraints);
java.awt.GridBagConstraints l2gridBagConstraints = new java.awt.GridBagConstraints();
l2gridBagConstraints.gridx = 0;
l2gridBagConstraints.gridy = 1;
l2gridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
l2gridBagConstraints.insets = new java.awt.Insets(0, 3, 0, 0);
jDialogContentPane.add(jLabel2, l2gridBagConstraints);
java.awt.GridBagConstraints l3gridBagConstraints = new java.awt.GridBagConstraints();
l3gridBagConstraints.gridx = 0;
l3gridBagConstraints.gridy = 2;
l3gridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
l3gridBagConstraints.insets = new java.awt.Insets(0, 3, 0, 0);
jDialogContentPane.add(jLabel3, l3gridBagConstraints);
java.awt.GridBagConstraints l4gridBagConstraints = new java.awt.GridBagConstraints();
l4gridBagConstraints.gridx = 0;
l4gridBagConstraints.gridy = 3;
l4gridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
l4gridBagConstraints.insets = new java.awt.Insets(0, 3, 0, 0);
jDialogContentPane.add(jLabel4, l4gridBagConstraints);
java.awt.GridBagConstraints l5gridBagConstraints = new java.awt.GridBagConstraints();
l5gridBagConstraints.gridx = 0;
l5gridBagConstraints.gridy = 5;
l5gridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
l5gridBagConstraints.insets = new java.awt.Insets(0, 3, 0, 0);
jDialogContentPane.add(jLabel5, l5gridBagConstraints);
java.awt.GridBagConstraints ntfgridBagConstraints = new java.awt.GridBagConstraints();
ntfgridBagConstraints.gridx = 1;
ntfgridBagConstraints.gridy = 0;
ntfgridBagConstraints.gridwidth = 5;
ntfgridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
ntfgridBagConstraints.ipadx = 396;
ntfgridBagConstraints.ipady = 10;
ntfgridBagConstraints.insets = new java.awt.Insets(0, 10, 0, 3);
jDialogContentPane.add(nameJTextField, ntfgridBagConstraints);
java.awt.GridBagConstraints ptfgridBagConstraints = new java.awt.GridBagConstraints();
ptfgridBagConstraints.gridx = 1;
ptfgridBagConstraints.gridy = 1;
ptfgridBagConstraints.gridwidth = 4;
ptfgridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
ptfgridBagConstraints.ipadx = 396;
ptfgridBagConstraints.ipady = 10;
ptfgridBagConstraints.insets = new java.awt.Insets(0, 10, 0, 0);
jDialogContentPane.add(phoneJTextField, ptfgridBagConstraints);
java.awt.GridBagConstraints ptf2gridBagConstraints = new java.awt.GridBagConstraints();
ptf2gridBagConstraints.gridx = 1;
ptf2gridBagConstraints.gridy = 2;
ptf2gridBagConstraints.gridwidth = 4;
ptf2gridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
ptf2gridBagConstraints.ipadx = 396;
ptf2gridBagConstraints.ipady = 10;
ptf2gridBagConstraints.insets = new java.awt.Insets(0, 10, 0, 0);
jDialogContentPane.add(phone2JTextField, ptf2gridBagConstraints);
java.awt.GridBagConstraints statgridBagConstraints = new java.awt.GridBagConstraints();
statgridBagConstraints.gridx = 1;
statgridBagConstraints.gridy = 3;
statgridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
statgridBagConstraints.insets = new java.awt.Insets(0, 10, 0, 0);
jDialogContentPane.add(statusjComboBox, statgridBagConstraints);
java.awt.GridBagConstraints ngridBagConstraints = new java.awt.GridBagConstraints();
ngridBagConstraints.gridx = 1;
ngridBagConstraints.gridy = 5;
ngridBagConstraints.gridwidth = 5;
ngridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
ngridBagConstraints.ipadx = 500;
ngridBagConstraints.ipady = 10;
ngridBagConstraints.insets = new java.awt.Insets(0, 10, 0, 3);
jDialogContentPane.add(jTextFieldNotes, ngridBagConstraints);
java.awt.GridBagConstraints okgridBagConstraints = new java.awt.GridBagConstraints();
okgridBagConstraints.gridx = 1;
okgridBagConstraints.gridy = 6;
okgridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
okgridBagConstraints.insets = new java.awt.Insets(0, 10, 0, 0);
jDialogContentPane.add(jButtonOk, okgridBagConstraints);
java.awt.GridBagConstraints cancelgridBagConstraints = new java.awt.GridBagConstraints();
cancelgridBagConstraints.gridx = 5;
cancelgridBagConstraints.gridy = 6;
cancelgridBagConstraints.fill = java.awt.GridBagConstraints.VERTICAL;
cancelgridBagConstraints.anchor = java.awt.GridBagConstraints.EAST;
cancelgridBagConstraints.insets = new java.awt.Insets(0, 0, 0, 3);
jDialogContentPane.add(cancle, cancelgridBagConstraints);
java.awt.GridBagConstraints prigridBagConstraints = new java.awt.GridBagConstraints();
prigridBagConstraints.gridx = 2;
prigridBagConstraints.gridy = 3;
prigridBagConstraints.gridwidth = 2;
prigridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
jDialogContentPane.add(prijLabel, prigridBagConstraints);
java.awt.GridBagConstraints pricbgridBagConstraints = new java.awt.GridBagConstraints();
pricbgridBagConstraints.gridx = 4;
pricbgridBagConstraints.gridy = 3;
pricbgridBagConstraints.gridwidth = 2;
pricbgridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
pricbgridBagConstraints.insets = new java.awt.Insets(0, 0, 0, 3);
jDialogContentPane.add(priComboBox, pricbgridBagConstraints);
java.awt.GridBagConstraints lgridBagConstraints = new java.awt.GridBagConstraints();
lgridBagConstraints.gridx = 0;
lgridBagConstraints.gridy = 4;
lgridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
lgridBagConstraints.insets = new java.awt.Insets(0, 3, 0, 0);
jDialogContentPane.add(forjLabel, lgridBagConstraints);
java.awt.GridBagConstraints forgridBagConstraints = new java.awt.GridBagConstraints();
forgridBagConstraints.gridx = 1;
forgridBagConstraints.gridy = 4;
forgridBagConstraints.gridwidth = 5;
forgridBagConstraints.fill = java.awt.GridBagConstraints.BOTH;
forgridBagConstraints.ipadx = 260;
forgridBagConstraints.ipady = 5;
forgridBagConstraints.insets = new java.awt.Insets(0, 10, 0, 3);
jDialogContentPane.add(jComboBoxFor, forgridBagConstraints);
java.awt.GridBagConstraints sgridBagConstraints = new java.awt.GridBagConstraints();
sgridBagConstraints.gridx = 5;
sgridBagConstraints.gridy = 1;
sgridBagConstraints.gridheight = 2;
sgridBagConstraints.fill = java.awt.GridBagConstraints.HORIZONTAL;
sgridBagConstraints.insets = new java.awt.Insets(0, 0, 0, 3);
jDialogContentPane.add(jButtionJSwitch, sgridBagConstraints);
if(this.m_bfcall){
int i_inc = +1;
if(this.m_bfcall){
switch(i_switch){
case 0:
i_switch++;
break;
case 1:
i_switch++;
break;
default :
i_switch=0;
f.setText(text);
setVisible(false);
dispose();
this.m_bOkay=true;
setVisible(false);
setVisible(false);
dispose();
inx--;
return (pcall);
PhoneCall pcall= new PhoneCall(nameJTextField.getText(),phoneJTextField.getText() ,phone2JTextField..getText(),UserID,(String)jComboBoxFor.get SelectedItem(), jTextFieldNotes.getText(),(String)priComboBox.getSelectedIte m(),(String)statusjComboBox.getSelectedItem(),m_oErrLog,m_oD B);
return (pcall);
m_phone=phone;
m_phone2=phone2;
this.m_bfcall=true;
m_oCallList=p_list;
private javax.swing.JPanel jDialogContentPane; // VE does not support implicit components at this time
Content-Type: image/jpeg;
name="dialog.jpg"
filename="dialog.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAUDBAQEAwUEBAQFBQUGBwwIBwcH Bw8LCwkMEQ8S
EhEPERETFhwXExQaFRERGCEYGh0dHx8fExciJCIeJBweHx7/2wBDAQUFBQcG Bw4ICA4eFBEU
Hh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4e Hh4eHh7/wAAR
CAJXAz4DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJ
Re: VE importing NetBeans [message #8977 is a reply to message #8516] Mon, 08 December 2003 11:16 Go to previous messageGo to next message
>> features to one of my programs today so I would say I am off to a good
>> start.
>> * AddCallDLG.java
>> * @author david
>> * @version
>> /* Todo
>> fo you.
>> m_oErrLog=errorlog;
>> initComponents();
>> pack();
>> int retval=0;
>> try{
>> if (rs.next()){
>> retval=1;
>> else {
>> if (rs.next()){
>> return retval;
>> evt) {
>> closeDialog(evt);
>> evt) {
>> evt) {
>> evt) {
>> evt) {
>> private void
>> if(this.m_bfcall){
>> private void
>> private void
>> private void
>> textField){
>> private void
>> private void
>> private void
>> int i_inc = +1;
>> private void
>> private void
>> private void
>> if(this.m_bfcall){
>> private void
>> switch(i_switch){
>> case 0:
>> i_switch++;
>> break;
>> case 1:
>> i_switch++;
>> break;
>> default :
>> i_switch=0;
>> f.setText(text);
>> setVisible(false);
>> dispose();
>> this.m_bOkay=true;
>> setVisible(false);
>> private void
>> setVisible(false);
>> dispose();
>> while (inx>0 &&
>> false){
>> inx--;
>> return (pcall);
>> return (pcall);
>> m_phone=phone;
>> m_phone2=phone2;
>> this.m_bfcall=true;
>> m_oCallList=p_list;
> * AddCallDLG.java
> * @author david
> * @version
> /* Todo
> m_oErrLog=errorlog;
> initComponents();
> pack();
> int retval=0;
> try{
> if (rs.next()){
> retval=1;
> else {
> if (rs.next()){
> return retval;
> closeDialog(evt);
> if(this.m_bfcall){
> int i_inc = +1;
> if(this.m_bfcall){
> switch(i_switch){
> case 0:
> i_switch++;
> break;
> case 1:
> i_switch++;
> break;
> default :
> i_switch=0;
> f.setText(text);
> setVisible(false);
> dispose();
> this.m_bOkay=true;
> m_
Re: VE importing NetBeans [message #9163 is a reply to message #8977] Tue, 09 December 2003 09:03 Go to previous messageGo to next message
> Netbeans does generate a .form file that is in XML that defines the Form.
> I do not know if importing from NetBeans is even on the VE new feature
> list. But I had have a lot of .forms that I would be glad ot share with
> you all if it is wanted or needed.
Thanks. I would be interested to see a .forms file structure.
In any case, the goal of VE is to be able to deal with common code
patterns off hand, so that it becomes a *visual code assist* on steroids
for GUI building ;-) regardless of how the code was originated. The
NetBean pattern is quite common; and mostly recognized today by VE.
Re: VE importing NetBeans [message #9186 is a reply to message #9163] Tue, 09 December 2003 10:11 Go to previous messageGo to next message
--------------070402050305020508040502
Here is the .form file for that file I posted earlyer. It looks like a
pretty easy to parse XML File to me.
BTW this is part of our telephone call system that I wrote. It replaced
a system that was written in Delphi that used XBase as the backend. I
wrote the Java based system after only playing with Java a few weeks. It
has been up for 3 years without a single crash. I for one am pretty fond
of Java on the desktop.
Content-Type: text/xml;
name="AddCallDLG.form"
filename="AddCallDLG.form"
<?xml version="1.0" encoding="UTF-8" ?>
<Form version="1.0" type="org.netbeans.modules.form.forminfo.JDialogFormInfo">
<Properties>
<Property name="title" type="java.lang.String" value="Add a Call"/>
</Properties>
<SyntheticProperties>
<SyntheticProperty name="formSizePolicy" type="int" value="2"/>
</SyntheticProperties>
<Events>
<EventHandler event="componentShown" listener="java.awt.event.ComponentListener" parameters="java.awt.event.ComponentEvent" handler="formComponentShown"/>
<EventHandler event="windowClosing" listener="java.awt.event.WindowListener" parameters="java.awt.event.WindowEvent" handler="closeDialog"/>
</Events>
<AuxValues>
<AuxValue name="designerSize" type="java.awt.Dimension" value=" -84,-19,0,5,115,114,0,18,106,97,118,97,46,97,119,116,46,68,1 05,109,101,110,115,105,111,110,65,-114,-39,-41,-84,95,68,20, 2,0,2,73,0,6,104,101,105,103,104,116,73,0,5,119,105,100,116, 104,120,112,0,0,1,44,0,0,2,68 "/>
</AuxValues>
<Layout class=" org.netbeans.modules.form.compat2.layouts.DesignGridBagLayou t "/>
<SubComponents>
<Component class="javax.swing.JLabel" name="jLabel1">
<Properties>
<Property name="displayedMnemonic" type="int" value="78"/>
<Property name="font" type="java.awt.Font" editor="org.netbeans.beaninfo.editors.FontEditor">
<Font name="Dialog" size="14" style="0"/>
</Property>
<Property name="labelFor" type="java.awt.Component" editor="org.netbeans.modules.form.ComponentChooserEditor">
<ComponentRef name="nameJTextField"/>
</Property>
<Property name="text" type="java.lang.String" value="Name"/>
</Properties>
<Constraints>
<Constraint layoutClass=" org.netbeans.modules.form.compat2.layouts.DesignGridBagLayou t " value=" org.netbeans.modules.form.compat2.layouts.DesignGridBagLayou t$GridBagConstraintsDescription ">
<GridBagConstraints gridX="0" gridY="0" gridWidth="1" gridHeight="1" fill="1" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="3" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JLabel" name="jLabel2">
<Properties>
<Property name="displayedMnemonic" type="int" value="80"/>
</Property>
<ComponentRef name="phoneJTextField"/>
</Property>
<Property name="text" type="java.lang.String" value="Phone"/>
</Properties>
<Constraints>
<GridBagConstraints gridX="0" gridY="1" gridWidth="1" gridHeight="1" fill="1" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="3" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JLabel" name="jLabel3">
<Properties>
<Property name="displayedMnemonic" type="int" value="50"/>
</Property>
<ComponentRef name="phone2JTextField"/>
</Property>
<Property name="text" type="java.lang.String" value="Phone2"/>
</Properties>
<Constraints>
<GridBagConstraints gridX="0" gridY="2" gridWidth="1" gridHeight="1" fill="1" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="3" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JLabel" name="jLabel4">
<Properties>
<Property name="displayedMnemonic" type="int" value="97"/>
</Property>
<ComponentRef name="statusjComboBox"/>
</Property>
<Property name="text" type="java.lang.String" value="Status"/>
</Properties>
<Constraints>
<GridBagConstraints gridX="0" gridY="3" gridWidth="1" gridHeight="1" fill="1" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="3" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JLabel" name="jLabel5">
<Properties>
<Property name="displayedMnemonic" type="int" value="116"/>
</Property>
<ComponentRef name="jTextFieldNotes"/>
</Property>
<Property name="text" type="java.lang.String" value="Note"/>
</Properties>
<Constraints>
<GridBagConstraints gridX="0" gridY="5" gridWidth="1" gridHeight="1" fill="1" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="3" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JTextField" name="nameJTextField">
<Events>
<EventHandler event="focusGained" listener="java.awt.event.FocusListener" parameters="java.awt.event.FocusEvent" handler="nameJTextFieldFocusGained"/>
<EventHandler event="keyTyped" listener="java.awt.event.KeyListener" parameters="java.awt.event.KeyEvent" handler="nameJTextFieldKeyTyped"/>
</Events>
<Constraints>
<GridBagConstraints gridX="1" gridY="0" gridWidth="5" gridHeight="1" fill="1" ipadX="396" ipadY="10" insetsTop="0" insetsLeft="10" insetsBottom="0" insetsRight="3" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JTextField" name="phoneJTextField">
<Events>
<EventHandler event="focusGained" listener="java.awt.event.FocusListener" parameters="java.awt.event.FocusEvent" handler="phoneJTextFieldFocusGained"/>
<EventHandler event="keyTyped" listener="java.awt.event.KeyListener" parameters="java.awt.event.KeyEvent" handler="phoneJTextFieldKeyTyped"/>
</Events>
<Constraints>
<GridBagConstraints gridX="1" gridY="1" gridWidth="4" gridHeight="1" fill="1" ipadX="396" ipadY="10" insetsTop="0" insetsLeft="10" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JTextField" name="phone2JTextField">
<Events>
<EventHandler event="focusGained" listener="java.awt.event.FocusListener" parameters="java.awt.event.FocusEvent" handler="phone2JTextFieldFocusGained"/>
<EventHandler event="keyTyped" listener="java.awt.event.KeyListener" parameters="java.awt.event.KeyEvent" handler="phone2JTextFieldKeyTyped"/>
</Events>
<Constraints>
<GridBagConstraints gridX="1" gridY="2" gridWidth="4" gridHeight="1" fill="1" ipadX="396" ipadY="10" insetsTop="0" insetsLeft="10" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JComboBox" name="statusjComboBox">
<Events>
<EventHandler event="actionPerformed" listener="java.awt.event.ActionListener" parameters="java.awt.event.ActionEvent" handler="statusjComboBoxActionPerformed"/>
<EventHandler event="mouseWheelMoved" listener="java.awt.event.MouseWheelListener" parameters="java.awt.event.MouseWheelEvent" handler="statusjComboBoxMouseWheelMoved"/>
</Events>
<AuxValues>
<AuxValue name="JavaCodeGenerator_CreateCodePost" type="java.lang.String" value=""/>
</AuxValues>
<Constraints>
<GridBagConstraints gridX="1" gridY="3" gridWidth="1" gridHeight="1" fill="1" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="10" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JTextField" name="jTextFieldNotes">
<Events>
<EventHandler event="focusGained" listener="java.awt.event.FocusListener" parameters="java.awt.event.FocusEvent" handler="jTextFieldNotesFocusGained"/>
<EventHandler event="keyTyped" listener="java.awt.event.KeyListener" parameters="java.awt.event.KeyEvent" handler="jTextFieldNotesKeyTyped"/>
</Events>
<Constraints>
<GridBagConstraints gridX="1" gridY="5" gridWidth="5" gridHeight="1" fill="1" ipadX="500" ipadY="10" insetsTop="0" insetsLeft="10" insetsBottom="0" insetsRight="3" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JButton" name="jButtonOk">
<Properties>
<Property name="mnemonic" type="int" value="79"/>
<Property name="text" type="java.lang.String" value="Ok"/>
<Property name="selected" type="boolean" value="true"/>
</Properties>
<Events>
<EventHandler event="actionPerformed" listener="java.awt.event.ActionListener" parameters="java.awt.event.ActionEvent" handler="jButtonOkActionPerformed"/>
</Events>
<Constraints>
<GridBagConstraints gridX="1" gridY="6" gridWidth="1" gridHeight="1" fill="1" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="10" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JButton" name="cancle">
<Properties>
<Property name="mnemonic" type="int" value="67"/>
<Property name="text" type="java.lang.String" value="Cancel"/>
</Properties>
<Events>
<EventHandler event="actionPerformed" listener="java.awt.event.ActionListener" parameters="java.awt.event.ActionEvent" handler="cancleActionPerformed"/>
</Events>
<Constraints>
<GridBagConstraints gridX="5" gridY="6" gridWidth="1" gridHeight="1" fill="3" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="0" insetsBottom="0" insetsRight="3" anchor="13" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JLabel" name="prijLabel">
<Properties>
<Property name="displayedMnemonic" type="int" value="114"/>
</Property>
<ComponentRef name="priComboBox"/>
</Property>
<Property name="text" type="java.lang.String" value="Priority "/>
<Property name="name" type="java.lang.String" value="Add Call"/>
</Properties>
<Constraints>
<GridBagConstraints gridX="2" gridY="3" gridWidth="2" gridHeight="1" fill="1" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="0" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JComboBox" name="priComboBox">
<Events>
<EventHandler event="mouseWheelMoved" listener="java.awt.event.MouseWheelListener" parameters="java.awt.event.MouseWheelEvent" handler="priComboBoxMouseWheelMoved"/>
</Events>
<Constraints>
<GridBagConstraints gridX="4" gridY="3" gridWidth="2" gridHeight="1" fill="1" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="0" insetsBottom="0" insetsRight="3" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JLabel" name="forjLabel">
<Properties>
<Property name="displayedMnemonic" type="int" value="70"/>
</Property>
<ComponentRef name="jComboBoxFor"/>
</Property>
<Property name="text" type="java.lang.String" value="For"/>
</Properties>
<Constraints>
<GridBagConstraints gridX="0" gridY="4" gridWidth="1" gridHeight="1" fill="1" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="3" insetsBottom="0" insetsRight="0" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JComboBox" name="jComboBoxFor">
<Events>
<EventHandler event="mouseReleased" listener="java.awt.event.MouseListener" parameters="java.awt.event.MouseEvent" handler="jComboBoxForMouseReleased"/>
<EventHandler event="mouseWheelMoved" listener="java.awt.event.MouseWheelListener" parameters="java.awt.event.MouseWheelEvent" handler="jComboBoxForMouseWheelMoved"/>
<EventHandler event="propertyChange" listener="java.beans.PropertyChangeListener" parameters="java.beans.PropertyChangeEvent" handler="jComboBoxForPropertyChange"/>
</Events>
<Constraints>
<GridBagConstraints gridX="1" gridY="4" gridWidth="5" gridHeight="1" fill="1" ipadX="260" ipadY="5" insetsTop="0" insetsLeft="10" insetsBottom="0" insetsRight="3" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
<Component class="javax.swing.JButton" name="jButtionJSwitch">
<Properties>
<Property name="mnemonic" type="int" value="83"/>
<Property name="text" type="java.lang.String" value="Switch"/>
</Properties>
<Events>
<EventHandler event="actionPerformed" listener="java.awt.event.ActionListener" parameters="java.awt.event.ActionEvent" handler="jButtionJSwitchActionPerformed"/>
</Events>
<Constraints>
<GridBagConstraints gridX="5" gridY="1" gridWidth="1" gridHeight="2" fill="2" ipadX="0" ipadY="0" insetsTop="0" insetsLeft="0" insetsBottom="0" insetsRight="3" anchor="10" weightX="0.0" weightY="0.0"/>
</Constraint>
</Constraints>
</Component>
</SubComponents>
</Form>
--------------070402050305020508040502--
Re: VE importing NetBeans [message #110571 is a reply to message #8208] Fri, 04 November 2005 15:58 Go to previous messageGo to next message
Originally posted by: dennis.dataaccess.com
On Thu, 04 Dec 2003 10:28:55 -0500, David Siebert
>little slow.
>> Thanks...
>> Peter walker
Hi all,
I just had the same experience. I'm pretty surprised this has not
changed in almost 2 years...
Dennis
Re: VE importing NetBeans [message #110588 is a reply to message #110571] Fri, 04 November 2005 17:14 Go to previous message
>Hi all,
>Regards,
>Dennis
I have now read the other threads about doing this, and I have to say
it's pretty lame that Eclipse doesn't just handle this more
appropriately, such as asking the user if he/she wants to convert the
code, or just doing so. Importing existing NetBeans visual code like
this turns out to be either a tedious project to get it right, or
winds up having weird looking stuff that's hard to work with if you
want to make changes in the VE later.
Dennis
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #567543 is a reply to message #2400] Thu, 20 November 2003 10:12 Go to previous message
Thorbjoern,
Regards...
Peter Walker
"Thorbj
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #567577 is a reply to message #2400] Thu, 20 November 2003 10:17 Go to previous message
Thanks, Rich Kulp
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #567746 is a reply to message #2459] Thu, 20 November 2003 22:50 Go to previous message
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #568137 is a reply to message #2430] Fri, 21 November 2003 11:47 Go to previous message
Peter Walker wrote:
> Thorbjoern,
> Regards...
> Peter Walker
for a while then :)
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #568169 is a reply to message #2669] Fri, 21 November 2003 12:21 Go to previous message
-bob
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #569325 is a reply to message #3827] Tue, 25 November 2003 21:41 Go to previous message
> Cheers,
> -bob
Dave
Dave Orme
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #569716 is a reply to message #5558] Wed, 26 November 2003 16:41 Go to previous message
> > Cheers,
> > -bob
Scott
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #570546 is a reply to message #2669] Sun, 30 November 2003 09:31 Go to previous message
johan
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #571816 is a reply to message #2430] Wed, 03 December 2003 16:46 Go to previous message
Peter Walker wrote:
> Thorbjoern,
> Regards...
> Peter Walker
> basis?
Re: Does VE also run under 3.0M4? 2.1.2 is listed as a prerequisite? [message #571899 is a reply to message #8084] Thu, 04 December 2003 09:03 Go to previous message
Thanks...
Peter walker
> Peter Walker wrote:
> > Thorbjoern,
newsgroup:
we're
> > Regards...
> > Peter Walker
> > "Thorbj
VE importing NetBeans [message #571997 is a reply to message #8145] Thu, 04 December 2003 10:28 Go to previous message
little slow.
> Thanks...
> Peter walker
>>Peter Walker wrote:
>>>Thorbjoern,
> newsgroup:
> we're
>>>Regards...
>>>Peter Walker
>>>basis?
Re: VE importing NetBeans [message #572087 is a reply to message #8208] Thu, 04 December 2003 12:47 Go to previous message
> posted.
> little slow.
>> work.
>> Thanks...
>> Peter walker
>>> Peter Walker wrote:
>>>> Thorbjoern,
>> newsgroup:
>> we're
>>>> Regards...
>>>> Peter Walker
>>>> "Thorbj
Re: VE importing NetBeans [message #572162 is a reply to message #8277] Thu, 04 December 2003 14:50 Go to previous message
* AddCallDLG.java
* @author david
* @version
/* Todo
m_oErrLog=errorlog;
initComponents();
pack();
int retval=0;
try{
if (rs.next()){
retval=1;
else {
if (rs.next()){
return retval;
closeDialog(evt);
if(this.m_bfcall){
int i_inc = +1;
if(this.m_bfcall){
switch(i_switch){
case 0:
i_switch++;
break;
case 1:
i_switch++;
break;
default :
i_switch=0;
f.setText(text);
setVisible(false);
dispose();
this.m_bOkay=true;
setVisible(false);
setVisible(false);
dispose();
inx--;
return (pcall);
return (pcall);
m_phone=phone;
m_phone2=phone2;
this.m_bfcall=true;
m_oCallList=p_list;
Re: VE importing NetBeans [message #572405 is a reply to message #8340] Fri, 05 December 2003 08:54 Go to previous message
> * AddCallDLG.java
> * @author david
> * @version
> /* Todo
> m_oErrLog=errorlog;
> initComponents();
> pack();
> int retval=0;
> try{
> if (rs.next()){
> retval=1;
> else {
> if (rs.next()){
> return retval;
> closeDialog(evt);
> if(this.m_bfcall){
> int i_inc = +1;
> if(this.m_bfcall){
> switch(i_switch){
> case 0:
> i_switch++;
> break;
> case 1:
> i_switch++;
> break;
> default :
> i_switch=0;
> f.setText(text);
> setVisible(false);
> dispose();
> this.m_bOkay=true;
> setVisible(false);
> setVisible(false);
> dispose();
> inx--;
> return (pcall);
> return (pcall);
> m_phone=phone;
> m_phone2=phone2;
> this.m_bfcall=true;
> m_oCallList=p_list;
* AddCallDLG.java
* @author david
* @version
/* Todo
m_oErrLog=errorlog;
initComponents();
pack();
int retval=0;
try{
if (rs.next()){
retval=1;
else {
if (rs.next()){
return retval;
closeDialog(evt);
if(this.m_bfcall){
int i_inc = +1;
if(this.m_bfcall){
switch(i_switch){
case 0:
i_switch++;
break;
case 1:
i_switch++;
break;
default :
i_switch=0;
f.setText(text);
setVisible(false);
dispose();
this.m_bOkay=true;
setVisible(false);
setVisible(false);
dispose();
inx--;
return (pcall);
return (pcall);
m_phone=phone;
m_phone2=phone2;
this.m_bfcall=true;
m_oCallList=p_list;
name="dialog.jpg"
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0R
Re: VE importing NetBeans [message #572811 is a reply to message #8516] Mon, 08 December 2003 11:16 Go to previous message
>> start.
>> * AddCallDLG.java
>> * @author david
>> * @version
>> /* Todo
>> fo you.
>> m_oErrLog=errorlog;
>> initComponents();
>> pack();
>> int retval=0;
>> try{
>> if (rs.next()){
>> retval=1;
>> else {
>> if (rs.next()){
>> return retval;
>> evt) {
>> closeDialog(evt);
>> evt) {
>> evt) {
>> evt) {
>> evt) {
>> private void
>> if(this.m_bfcall){
>> private void
>> private void
>> private void
>> textField){
>> private void
>> private void
>> private void
>> int i_inc = +1;
>> private void
>> private void
>> private void
>> if(this.m_bfcall){
>> private void
>> switch(i_switch){
>> case 0:
>> i_switch++;
>> break;
>> case 1:
>> i_switch++;
>> break;
>> default :
>> i_switch=0;
>> f.setText(text);
>> setVisible(false);
>> dispose();
>> this.m_bOkay=true;
>> setVisible(false);
>> private void
>> setVisible(false);
>> dispose();
>> while (inx>0 &&
>> false){
>> inx--;
>> return (pcall);
>> return (pcall);
>> m_phone=phone;
>> m_phone2=phone2;
>> this.m_bfcall=true;
>> m_oCallList=p_list;
> * AddCallDLG.java
> * @author david
> * @version
> /* Todo
> m_oErrLog=errorlog;
> initComponents();
> pack();
> int retval=0;
> try{
> if (rs.next()){
> retval=1;
> else {
> if (rs.next()){
> return retval;
> closeDialog(evt);
> if(this.m_bfcall){
> int i_inc = +1;
> if(this.m_bfcall){
> switch(i_switch){
> case 0:
> i_switch++;
> break;
> case 1:
> i_switch++;
> break;
> default :
> i_switch=0;
> f.setText(text);
> setVisible(false);
> dispose();
> this.m_bOkay=true;
> m_
Re: VE importing NetBeans [message #573142 is a reply to message #8977] Tue, 09 December 2003 09:03 Go to previous message
Re: VE importing NetBeans [message #573179 is a reply to message #9163] Tue, 09 December 2003 10:11 Go to previous message
<Properties>
</Properties>
<Events>
</Events>
<AuxValues>
</AuxValues>
<SubComponents>
<Properties>
</Property>
</Property>
</Properties>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Properties>
</Property>
</Property>
</Properties>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Properties>
</Property>
</Property>
</Properties>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Properties>
</Property>
</Property>
</Properties>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Properties>
</Property>
</Property>
</Properties>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Events>
</Events>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Events>
</Events>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Events>
</Events>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Events>
</Events>
<AuxValues>
</AuxValues>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Events>
</Events>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Properties>
</Properties>
<Events>
</Events>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Properties>
</Properties>
<Events>
</Events>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Properties>
</Property>
</Property>
</Properties>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Events>
</Events>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Properties>
</Property>
</Property>
</Properties>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Events>
</Events>
<Constraints>
</Constraint>
</Constraints>
</Component>
<Properties>
</Properties>
<Events>
</Events>
<Constraints>
</Constraint>
</Constraints>
</Component>
</SubComponents>
</Form>
Re: VE importing NetBeans [message #611296 is a reply to message #8208] Fri, 04 November 2005 15:58 Go to previous message
>little slow.
>> Thanks...
>> Peter walker
Hi all,
Dennis
Re: VE importing NetBeans [message #611297 is a reply to message #110571] Fri, 04 November 2005 17:14 Go to previous message
>Hi all,
>Regards,
>Dennis
Dennis
Previous Topic:extend VE - palette and editor
Next Topic:MoreSwingComponents fails 3.2M2
Current Time: Fri Jul 04 20:25:16 EDT 2025
Powered by FUDForum. Page generated in 0.53362 seconds
