Home » Eclipse Projects » Eclipse Platform » No property tester contributes a property processTypeTest to type class
No property tester contributes a property processTypeTest to type class [message #281815] Fri, 25 February 2005 16:46
Originally posted by: martinwesthead.yahoo.com
I am working on Eclipse 3.1M4. I have written a subclass of TextConsole
which seems to be working fine, except when I add the console to the
console manager (IConsoleManager.addConsoles()) I am encountering get a
core exception with the following message entered in the log:
Is this a bug or am I doing something wrong? Any help welcomed.
Martin
!ENTRY org.eclipse.ui.console 4 120 2005-02-25 13:21:21.786
!MESSAGE Error logged from Console plug-in:
!STACK 1
org.eclipse.core.runtime.CoreException: No property tester contributes a
com.internetdesigntools.ui.console.ConfigConsole
org.eclipse.core.internal.expressions.TypeExtensionManager.g etProperty(TypeExtensionManager.java:104)
org.eclipse.core.internal.expressions.TestExpression.evaluat e(TestExpression.java:54)
org.eclipse.core.internal.expressions.CompositeExpression.ev aluateOr(CompositeExpression.java:62)
org.eclipse.core.internal.expressions.OrExpression.evaluate( OrExpression.java:21)
org.eclipse.core.internal.expressions.CompositeExpression.ev aluateAnd(CompositeExpression.java:47)
org.eclipse.core.internal.expressions.EnablementExpression.e valuate(EnablementExpression.java:29)
org.eclipse.ui.internal.console.PatternMatchListenerExtensio n.isEnabledFor(PatternMatchListenerExtension.java:70)
org.eclipse.ui.internal.console.ConsoleManager.getPatternMat chListeners(ConsoleManager.java:333)
org.eclipse.ui.internal.console.ConsoleManager.addConsoles(C onsoleManager.java:173)
com.internetdesigntools.ui.console.ConfigConsole.register(Co nfigConsole.java:52)
com.internetdesigntools.ui.console.ConfigConsole.<init>(ConfigConsole.java:36)
com.internetdesigntools.ui.actions.ConnectAction.openConsole (ConnectAction.java:89)
com.internetdesigntools.ui.wizard.NewConnectionDescriptionWi zard.performFinish(NewConnectionDescriptionWizard.java:51)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:670)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:342)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:543)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:996)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2698)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2397)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
com.internetdesigntools.ui.actions.NewConnectionDescriptionA ction.run(NewConnectionDescriptionAction.java:54)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:244)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:220)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:555)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:505)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:460)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1569)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1540)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:220)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
!SUBENTRY 1 org.eclipse.core.expressions 4 201 2005-02-25 13:21:21.791
!MESSAGE No property tester contributes a property processTypeTest to
type class com.internetdesigntools.ui.console.ConfigConsole
Previous Topic:Get a reference to the editor page
Next Topic:Finding the class of an active view
Current Time: Tue Jul 22 15:31:25 EDT 2025
Powered by FUDForum. Page generated in 0.03482 seconds
