Home » Eclipse Projects » Nebula » CTableTree, CTree?????
CTableTree, CTree????? [message #27990] Thu, 08 February 2007 17:37 Go to next message
Originally posted by: alnospammajor.noboxspamspoon.com
what's going on with CTableTree? i just tried running my CTableTree
based code after a couple of months, and am getting lots of compilation
errors. among other things it looks like CTableTree has been renamed
CTree, but this doesn't actually compile.
before i investigate any further, i wanted to make sure that i'm not
missing anything obvious (like the code having moved to a different
repository). is there currently a working version of this widget?
al
Re: CTableTree, CTree????? [message #28030 is a reply to message #27990] Thu, 08 February 2007 17:47 Go to previous messageGo to next message
correction. it's the CTreeViewer that doesn't compile, not CTree.
al
Re: CTableTree, CTree????? [message #28068 is a reply to message #27990] Thu, 08 February 2007 17:56 Go to previous messageGo to next message
Yes, CTableTree is being renamed and refactored as CTree:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162138
The first working version is targeted for the end of February for gtk
and win32.
> al
Re: CTableTree, CTree????? [message #28107 is a reply to message #28030] Thu, 08 February 2007 18:01 Go to previous messageGo to next message
The CTreeViewer was rebuilt using a patched version of 3.3M4 to test all
of Tom's hard work. When 3.3M5 is out this viewer will be updated
accordingly and then things like TreePaths should work correctly :)
> al
Re: CTableTree, CTree????? [message #28145 is a reply to message #28107] Thu, 08 February 2007 18:24 Go to previous messageGo to next message
ahh. good. 3.3M5 is scheduled for tomorrow, so i should be able to test
it soon.
>> al
Re: CTableTree, CTree????? [message #28184 is a reply to message #28068] Thu, 08 February 2007 18:31 Go to previous message
i've started refactoring my own code to reflect the changes. most of it
is pretty self-explanatory from looking at the snippets.
i have a viewer class derived from the CTreeViewer (to override
doUpdateItem). it's calling doUpdateCell which appears to have
disappeared from the base class. is there a preferred replacement method?
btw, jeremy you may want to delete the
org.eclipse.swt.widgets.ctabletree package from the repository. that way
it'll be clear from compilation errors that all those classes have been
replaced by differently named ones.
regards,
al
> and win32.
>> compilation errors. among other things it looks like CTableTree has
>> been renamed CTree, but this doesn't actually compile.
>> al
Re: CTableTree, CTree????? [message #577986 is a reply to message #27990] Thu, 08 February 2007 17:47 Go to previous message
al
Re: CTableTree, CTree????? [message #578000 is a reply to message #27990] Thu, 08 February 2007 17:56 Go to previous message
and win32.
> al
Re: CTableTree, CTree????? [message #578008 is a reply to message #28030] Thu, 08 February 2007 18:01 Go to previous message
> al
Re: CTableTree, CTree????? [message #578042 is a reply to message #28107] Thu, 08 February 2007 18:24 Go to previous message
it soon.
>> al
Re: CTableTree, CTree????? [message #578081 is a reply to message #28068] Thu, 08 February 2007 18:31 Go to previous message
regards,
al
> and win32.
>> al
Previous Topic:CTableTree, CTree?????
Next Topic:label provider for grid viewer
Current Time: Sat Aug 02 04:16:27 EDT 2025
Powered by FUDForum. Page generated in 0.07457 seconds
