Home » Eclipse Projects » Eclipse Platform » How does eclipse know
How does eclipse know [message #281150] |
Tue, 15 February 2005 19:06  |
How does eclipse determine that a file is already open in an editor? Is
there a way that I can "plug-in" to that process to have some of my code
executed at that point?
Keith
Re: How does eclipse know [message #281155 is a reply to message #281153] |
Tue, 15 February 2005 19:56   |
CL [dnoyeb] Gilbert wrote:
>> Is there a way that I can "plug-in" to that process to have some of my
>> code executed at that point?
>> Thanks,
>> Keith
> I compares the IEditorInputs, and if they match it concludes the file is
> already open. create your own ieditorInput and put in a equals method,
> and set a breakpoint in it. Then you can follow the process.
> CL
That sort of sounds okay, but when I double-click a file in the
navigator view, it launches the OpenFileAction#openFile() method which
in turn invokes the IDE#openEditor() method. (I've done some more
digging since my original post). The problem is that the
IDE#openEditor() method just constructs a new FileEditorInput object. I
have looked at the extension points in the help, but I didn't see
anything that would allow me to specify which IEditorInput to use for a
certain file name/extension (there was something for the documentSetup,
documentCreation, and documentProvider, but nothing for the editor
input). Anyway, I need a way to "intercept" the detection of whether a
file is already open or not.
I appreciate you help,
Keith
Re: How does eclipse know [message #281156 is a reply to message #281155] |
Tue, 15 February 2005 21:23   |
Originally posted by: pascal.ibm.canada
Take a look at the extension point org.eclipse.ui.editors. It allows to
register a new editor with a given file extension.
PaScaL
>>> my code executed at that point?
>>> Thanks,
>>> Keith
>> is already open. create your own ieditorInput and put in a equals
>> method, and set a breakpoint in it. Then you can follow the process.
>> CL
> Keith
Re: How does eclipse know [message #281157 is a reply to message #281156] |
Tue, 15 February 2005 22:39   |
> PaScaL
>>>> editor? Is there a way that I can "plug-in" to that process to have
>>>> some of my code executed at that point?
>>>> Thanks,
>>>> Keith
>>> CL
>> I have looked at the extension points in the help, but I didn't see
>> a certain file name/extension (there was something for the
>> documentSetup, documentCreation, and documentProvider, but nothing for
>> the editor input). Anyway, I need a way to "intercept" the detection
>> of whether a file is already open or not.
>> Keith
I already have my own editor. What I don't have is way to control how
eclipse determines if a file is already open for editing. The default
functionality is fine for general purpose stuff, but I would like to
find a way to fine tune it if I can. My editor can be opened for any
one of 3 file extensions. 3 files related together are edited at once
in my editor. Eclipse allows each of the three files to be opened at
the same time in separate editors. I would like to be able to say that
if one of the files is open, then the user cannot open either of the
other two, until he/she closes the one that is currently open. I need
to be able to get my own logic into that file opening code. Anybody
have any clues?
Keith
PS I don't really mean to sound so snotty :-)
Re: How does eclipse know [message #281170 is a reply to message #281157] |
Wed, 16 February 2005 07:47   |
Originally posted by: Chris_Laffra.ca.ibm.com
In http://www.eclipsefaq.org/chris/faq/html/faq167.html there is a
description how editors are managed.
Perhaps that is a starting point for you?
Chris Laffra, http://eclipsefaq.org
"Keith McQueen" <kmcqueen@tsccos.com> wrote in message
news:cuuflc$fgf$1@www.eclipse.org...
> > PaScaL
> >>>> Thanks,
> >>>> Keith
> >>> CL
> >> Keith
> have any clues?
> Keith
Re: How does eclipse know [message #281173 is a reply to message #281157] |
Wed, 16 February 2005 09:16   |
> functionality is fine for general purpose stuff, but I would like to find
> a way to fine tune it if I can. My editor can be opened for any one of 3
> file extensions. 3 files related together are edited at once in my
> editor. Eclipse allows each of the three files to be opened at the same
> time in separate editors. I would like to be able to say that if one of
> the files is open, then the user cannot open either of the other two,
> until he/she closes the one that is currently open. I need to be able to
> get my own logic into that file opening code. Anybody have any clues?
Are those three files needed? Isn't it better to use only one file?
Why not providing an editor for the center file
(only one of those three is editable)?
For the other two provide editors opening a main editor instead?
You can dispose your editor at will. So maybe you can do it this way:
1. Be happy Eclipse creates an editor.
(hopefully you can prevent this, but I dont know yet)
2. Dispose your Editor once it is possible.
3. Before disposing your editor, select the apropriate editor and focus
it.
Since you are lightning fast, this shouldn't disturb anyone that much.
It's quite a hack and it shouldn't make it into your product code but
hey as long as you don't have another solution ... .
But there should be a better way for sure.
Martin (Kersten)
Re: How does eclipse know [message #281192 is a reply to message #281155] |
Wed, 16 February 2005 11:10  |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
You are out of luck. There are numerous enhancement requests that cover
what you are looking for. I can point you to a few when I get home if
you like?
The basic strategy is to create your IEditorInput, and even if you had
seperate IEditorInputs, as long as they returned true as being equal to
any of the other two types of IEditorInputs, the 'workbench' would not
open that file a 2nd time.
The problem is that its not the workbehch, IIRC, the Navigator is part
of the IDE plugin. And the IDE plugin will create its own IEditorInput
for your file. So you wont have an opportunity to create your own
'equals' method.
Its a pretty high demand feature it seems to me. Maybe you can vote for
one of the enhancement requests that best fit your requirements. The
discussions look promising, but it does appear to e quite a complicated
architectural thing to get engineered.
CL
>>> Thanks,
>>> Keith
>> CL
> Keith
Current Time: Sun Aug 31 18:40:29 EDT 2025
Powered by FUDForum. Page generated in 0.04820 seconds
