Home » Eclipse Projects » Eclipse Platform » Problem with adding tooltip for anntation
Problem with adding tooltip for anntation [message #280755] Wed, 09 February 2005 02:18 Go to next message
How can i add tooltip for error annotation marker in text editor?
I try this code that shown error marker in proper line, but error marker
have no tooltip.
--skip--
annotationModel.addAnnotation(new MyAnnotation(),new Position(...));
--skip--
class MyAnnotation() extends Annotation
public static final String ERROR_ANNOTATION_TYPE=
"org.eclipse.ui.workbench.texteditor.error"; //$NON-NLS-1$
public MyAnnotation()
setType(ERROR_ANNOTATION_TYPE);
setText("My annotation error msg");
Re: Problem with adding tooltip for anntation [message #280807 is a reply to message #280755] Thu, 10 February 2005 06:44 Go to previous messageGo to next message
> marker have no tooltip.
Are you talking about the built-in text editor or about one that you
provide yourself?
Dani
> --skip--
> --skip--
Re: Problem with adding tooltip for anntation [message #280842 is a reply to message #280807] Fri, 11 February 2005 00:13 Go to previous message
> provide yourself?
> Dani
About my text editor.
class MyTextEditor extends TextEditor
protected ISourceViewer createSourceViewer(Composite parent,
IVerticalRuler ruler, int styles)
ISourceViewer viewer= new ProjectionViewer(parent, ruler,
getOverviewRuler(), true, styles);
getSourceViewerDecorationSupport(viewer);
return viewer;
Previous Topic:Programatically passing arguments to ViewPart instances
Next Topic:How can I mix menu contributions by plugin.xml and workbenchAdvisor ?
Current Time: Sat Aug 30 02:22:46 EDT 2025
Powered by FUDForum. Page generated in 0.04258 seconds
