Home » Eclipse Projects » Eclipse Platform » Cannot repair the malformed "URL" field contained in "Edit Local Site" dialog wi
Cannot repair the malformed "URL" field contained in "Edit Local Site" dialog wi [message #280476] |
Thu, 03 February 2005 18:31  |
While testing my deployment process on Linux, I defined a "local" update
site on a Linux box (say: /home/tdj/workspace/my.update-site.project)
then when I tried to use it, I see messages on the console that lead me
to believe that the resultant URL (e.g. file:/home/tdj/ ... ) should
actually be something like file:///home/tdj ... which I think is a defect
in the construction of the URL
This led me to discover the second problem ... on Windows, I can clearly
see that the URL text box is not meant to be edited (it is grayed out).
On RedHat Enterprise Linux 3/GTK, the URL text box appears as if it is
editable, but it is not.
Are these considered legitimate defects? I didn't find them in Bugzilla,
so if someone else thinks they're worth reporting I will definitely
do so, with more precision.
Tom Johnson
Re: Cannot repair the malformed "URL" field contained in "Edit Local Site" dialo [message #280542 is a reply to message #280476] |
Fri, 04 February 2005 20:49   |
Originally posted by: dorian.birsan.net
The URL correct format must be your responsibility, but feel free to open
bug reports for the problems you encountered.
Even better, patches are greatly appreciated :-)
-dorian
"Tom Johnson" <tdjohns1@rockwellcollins.com> wrote in message
news:ctuc9b$apj$1@www.eclipse.org...
> Tom Johnson
Re: Cannot repair the malformed "URL" field contained in "Edit Local Site" dialo [message #280615 is a reply to message #280542] |
Mon, 07 February 2005 09:38   |
The URL was formatted by pressing the "Browse" button and
browsing. It seemed to me that should produce a properly
formatted URL. Oh well ...
> -dorian
>>Thanks,
>>Tom Johnson
Re: Cannot repair the malformed "URL" field contained in "Edit Local Site" dialo [message #280690 is a reply to message #280615] |
Mon, 07 February 2005 22:04  |
Originally posted by: bob.objfac.com
Either one file:/ or three file:/// should work, but not all systems
agree. Microsoft uses file:///, so pretty near everyone else supports it.
However, if a Browse button produced the URI and it doesn't work on your
system, it's definitely somebody's bug.
Bob Foster
>> -dorian
>>> defect
>>> Bugzilla,
>>> Thanks,
>>> Tom Johnson
Current Time: Sun Aug 31 18:27:13 EDT 2025
Powered by FUDForum. Page generated in 0.03811 seconds
