Home » Eclipse Projects » Eclipse Platform » Attaching KeyListener (or some such) to AbstractTextEditor
Attaching KeyListener (or some such) to AbstractTextEditor [message #280074] Fri, 28 January 2005 05:42 Go to next message
Originally posted by: iwan.global.co.za
I need a way to intercept each key press (or change in the unsaved text of
the editor) in a subclass of AbstractTextEditor.
Any pointers as to how I can do that?
Context: I have an editor that edits a string buffer, and I do not want to
save in the editor in order to update the string buffer - I want to keep
the buffer in synch with the unsaved buffer in the editor.
-i
Re: Attaching KeyListener (or some such) to AbstractTextEditor [message #280083 is a reply to message #280074] Fri, 28 January 2005 09:31 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Iwan Vosloo wrote:
> Hello,
> text of the editor) in a subclass of AbstractTextEditor.
> want to save in the editor in order to update the string buffer - I
> want to keep the buffer in synch with the unsaved buffer in the editor.
You mean you want to keep the buffer up to date while typing?
Dani
> Thanks
> -i
Re: Attaching KeyListener (or some such) to AbstractTextEditor [message #280116 is a reply to message #280083] Sat, 29 January 2005 05:54 Go to previous messageGo to next message
> Dani
Yes, exactly.
-i
Re: Attaching KeyListener (or some such) to AbstractTextEditor [message #280156 is a reply to message #280116] Mon, 31 January 2005 09:31 Go to previous messageGo to next message
>> Dani
> Yes, exactly.
If you type the underlying document / buffer gets updated automatically.
Dani
> -i
Re: Attaching KeyListener (or some such) to AbstractTextEditor [message #280204 is a reply to message #280156] Mon, 31 January 2005 18:03 Go to previous message
Originally posted by: Chris_Laffra.ca.ibm.com
See org.eclipse.swt.custom.StyledText.modifyContent
If you register a document listener you will be called when the document
changes.
See
org.eclipse.jface.text.presentation.PresentationReconciler$I nternalListener.
documentChanged
for an example.
Chris Laffra, http://eclipsefaq.org
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:ctlfff$k4$1@www.eclipse.org...
editor.
> >> Dani
> > Yes, exactly.
> Dani
> > -i
Previous Topic:javax.comm, commapi, serial ports within eclipse
Next Topic:[ANN] The Java Developer's Guide to Eclipse: CD-ROM preview at www.jdg2e.com
Current Time: Thu Nov 27 20:49:06 EST 2025
Powered by FUDForum. Page generated in 0.04657 seconds
