Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » problem markers
problem markers [message #27833] |
Mon, 07 July 2008 19:35  |
I know how to report a problem in the problems view (if it is enabled and
available),
i.e. by calling IProblemReporter.reportProblem. However, I am not sure how
if/how
to add the returned problem marker (IMarker) to an editor window.
Would someone please tell me:
a) Is it necessary to do something with the returned marker or is a
marker automatically added to your editor window?
b) If you need to do something, what exactly do you have to do with that
marker?
Chuck
Re: problem markers [message #28228 is a reply to message #27875] |
Fri, 11 July 2008 16:17   |
As I said, I create problem markers by calling
I am using the default annotation model. I haven't debugged that yet, but I
assume I shouldn't have to.
Apparently, problems are associated with a resource since
DLTKProblemReporter.reportProblem calls IResource.createMarker.
My issues now are that:
a) Sometimes problems are cleared that aren't resolved (perhaps because
their source position changed?)
b) Sometimes the same problem is listed multiple times.
I don't see how this could happen if I/we always call
IProblemReporter.clearMarkers before every call to:
a) parse
b) do semantic checks
Chuck
"Alex Panchenko" <alex@xored.com> wrote in message
news:g4us26$9gd$1@build.eclipse.org...
> Hi Chuck,
> markers in the editor window are managed by the
> org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider.SourceModuleAnnotationModel
> It should listen to marker changes and update markers automatically.
> Actually the marker change listener is in the base class
> org.eclipse.ui.texteditor.ResourceMarkerAnnotationModel.
> If something does not work for you - you need to check what annotation
> model is created for your editor - start debug at the
> SourceModuleDocumentProvider#createFileInfo(Object element)
> Alex
>> available),
>> how if/how
>> that marker?
>> Thanks,
>> Chuck
Re: problem markers [message #28265 is a reply to message #28228] |
Fri, 11 July 2008 16:50   |
At least some of this may have happened since my builder was not clearing
the markers.
It is now.
Thus,
a) initially the file is built when the project is opened (and the problems
window is populated as needed)
b) the file is edited dynamically and the problems window is cleared and
repopulated (via reconcilation and my semantic checker being called from
ISourceElementParser.parse)
c) the file is saved, and incremental build is started, and the problems
window is cleared and repopulated
Chuck
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:g58f7l$phr$1@build.eclipse.org...
> I assume I shouldn't have to.
> a) parse
> Chuck
>> Hi Chuck,
>> Regards,
>> Alex
>>> and available),
>>> how if/how
>>> that marker?
>>> Thanks,
>>> Chuck
Re: problem markers [message #28303 is a reply to message #28265] |
Mon, 14 July 2008 00:50   |
Hi Chuck,
I am improving error reporting & marker operations now.
The results would be
a) reconcilation in the editor will not touch markers - errors will be
visualized via annotations.
b) builder will be parsing all files and creating error markers if there
were any problems encountered.
c) also there are ideas to introduces API so it would be possible to
easier integrate checkers in the build process.
Probably you should wait a few days until this work is finished and
after that build against CVS HEAD.
Alex
> the markers.
> It is now.
> Thus,
> Chuck
>> a) parse
>> Chuck
>>> Hi Chuck,
>>> Regards,
>>> Alex
>>>> and available),
>>>> how if/how
>>>> that marker?
>>>> Thanks,
>>>> Chuck
Re: problem markers [message #28415 is a reply to message #28303] |
Mon, 14 July 2008 03:28   |
hi Alex,
I have a similar issue with error reporting.
In my case, suppose i opened a script file, make a small change so as to
produce a syntax error, the reconciler runs my syntax checker and shows
the errors in problems view.
So far so good; now do not save the file and close it without saving, the
problems view is not cleared.
When i reopen the file, it opens the saved file which doesnot have any
syntax errors. But my problems view still shows errors of the unsaved
version.
I tried to debug and found that getProblemReporter() in
AbstractSourceElementParser is null, for first parse on the script file,
which is why it fails.
Can you help me please.
Thanks and regards,
Abhijit.
Alex wrote:
Hi Chuck,
Probably you should wait a few days until this work is finished and after
Alex
Re: problem markers [message #28448 is a reply to message #28415] |
Tue, 15 July 2008 09:41  |
Hi all,
This is fixed in CVS HEAD
You can download 1.0 integration build at
http://download.eclipse.org/technology/dltk/downloads/
Reagrds,
Alex
Abhijit wrote:
> hi Alex,
> the problems view is not cleared.
> version.
> Thanks and regards,
> Abhijit.
> Alex wrote:
> Hi Chuck,
> Alex
Current Time: Mon Jul 21 00:46:53 EDT 2025
Powered by FUDForum. Page generated in 1.08595 seconds
