AJDT in WSAD5.0.1: compile failed [message #27819] |
Sun, 09 November 2003 15:20  |
Originally posted by: jll.lilly.com
Help needed...
Is there anybody using AspectJ with WSAD 5.0.1 and experiencing the
following problem:
when I create a project from scratch everything seems to work fine but
when I try to transpose this into an existing project, I always get an
error message "Compile failed: reason: compile failed" whatever there's in
the aspects I try to write and even if there's no aspect at all...
I cannot figure out what's wrong but I have a clue: the existing projet is
under version control in ClearCase/ClearQuest (tools from Rational) but
the newly created project is not.
Any idea? Any additional detail needed to diagnose?
J.-L. Libioulle
Re: AJDT in WSAD5.0.1: compile failed [message #28406 is a reply to message #28371] |
Fri, 05 December 2003 10:59  |
Originally posted by: klholmes.open-iq.com
After considering your ealier post and creating the project from scratch
as an AspectJ project rather than converting and existing project, I found
the same thing.
A recursive compare (Beyond Compare rocks !) on the two resulting project
directories found a difference in the .classpath files.
Try adding the following to a problem-converted-project .classpath file
<classpathentry kind="con"
path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
This seemed to fix the problem for me.
However my "generate and deploy" code problem from my earlier post still
stands.
Kevin Holmes wrote:
> apologies in advance JL, I dont have an answer for you, but maybe some
> more information. We might have the same problem, see my post on the 5th.
> Do you see the same classpath problem stacktrace in your .metadata/.log
> file ?
> JL Libioulle wrote:
> > Help needed...
> > following problem:
> > Regards,
> > J.-L. Libioulle
Re: AJDT in WSAD5.0.1: compile failed [message #573379 is a reply to message #27819] |
Fri, 05 December 2003 10:08  |
file ?
JL Libioulle wrote:
> Help needed...
> following problem:
> J.-L. Libioulle
Re: AJDT in WSAD5.0.1: compile failed [message #573414 is a reply to message #28371] |
the same thing.
stands.
> file ?
> JL Libioulle wrote:
> > Help needed...
> > following problem:
> > Regards,
> > J.-L. Libioulle
FUDForum. Page generated in 0.08429 seconds
