Plugin Deleopment [message #279644] |
Thu, 20 January 2005 23:41  |
Originally posted by: aprakash.visolve.com
Hello All,
I had a problem while developing view plugin. Program is, just display an
message in an view. I created an plugin.xml and jar file for the plugin. I
placed these files in the plugin folder. What when i open the eclipse
eclipse next time, the view is not there and there is an error log message.
Java Program:
package HelloWorld;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.SWT;
import org.eclipse.ui.part.ViewPart;
public class HelloWorldView extends ViewPart {
Label label;
public HelloWorldView() {
super();
public void createPartControl(Composite parent) {
label = new Label(parent,SWT.WRAP);
label.setText("Hello World");
public void setFocus() {
plugin.xml:
<?eclipse version="3.0"?>
<plugin
id="HelloWorld"
name="HelloWorld Plug-in"
version="1.0.0"
provider-name=""
class="HelloWorld.HelloWorldView">
<runtime>
<library name="HelloWorld.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.core.runtime"/>
</requires>
<extension
point="org.eclipse.ui.views">
<catagory
id="org.eclipse.examples.helloworld.hello"
name="Hello"/>
<view
id="org.eclipse.examples.helloworld.helloworldview"
name="Hello Greetings"
catagory="org.eclipse.examples.helloworld.hello"
class="org.eclipse.examples.helloworld.HelloWorldView"/>
</extension>
</plugin>
Error Message:
Problems encountered while PDE was scanning the Target platform
Missing required plugin org.eclipse.perfmsr.core_0.0.0
Thanks in Advance,
Prakash.A
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: Plugin Deleopment [message #279747 is a reply to message #279688] |
Mon, 24 January 2005 02:03  |
Thank you for your reply. But the problem is, there is no new view
present in
Window > Show view > other. I think there is some problem in the program
and pde plugin.
i downloaded the PDE from
( http://download.eclipse.org/downloads/drops/R-3.0-2004062512 08/eclipse-PDE-3.0.zip).
Once Again i remind you the error i got:
Error Message:
On Fri, 21 Jan 2005 10:51:51 -0500, Chris Laffra <Chris_Laffra@ca.ibm.com>
wrote:
> The error is unrelated to your view. You have to open the view by hand.
> See Window > Show view > Other...
"Prakash" <aprakash@visolve.com> wrote in message
news:opskxrbenqo9gg4b@pra-co...
> Hello All,
> I
message.
> Java Program:
> package HelloWorld;
> Label label;
> super();
> plugin.xml:
> <plugin
> id="HelloWorld"
> version="1.0.0"
> provider-name=""
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> <requires>
> </requires>
> <extension
> <catagory
> name="Hello"/>
> <view
> </extension>
> </plugin>
> Error Message:
> Thanks in Advance,
> Prakash.A
> --Using Opera's revolutionary e-mail client: http://www.opera.com/m2
FUDForum. Page generated in 0.29221 seconds
