Building JWT workflows between plug-ins contributed to a RCP. [message #27761] |
Wed, 11 February 2009 06:03  |
Hi guys,
I'm just starting to learn about JWT, but I'm still unsure if there is
some way to leverage it for my specific requirements:
I am building a RCP for plug-ins that provide various functionality
(editors, calculations, etc) for a common data model.
I need to define a workflow to specify the order in which different
plug-ins should perform their specific data model transformations.
The plug-ins which contribute "tasks" to the workflow may not necessarily
be present. For example, the superannuation data should be calculated if
the superannuation plug-in is installed. I don't mind defining where it
should contribute a task on a workflow diagram, but that task should be
ignored if the superannuation plug-in isn't installed. My application is
intended to be a platform for other plug-in development.
Is this something that JWT can assist with, or perhaps some other
technology? Can I define and execute a JWT workflow using tasks
contributed by different plug-ins (that may or may not be present)?
I'm happy to write the workflow engine myself, but it would be a shame to
do that if someone else has already done to the good work.
I'm researching this as quickly as I can, but any assistance would be
fantastic at this stage!
Re: Building JWT workflows between plug-ins contributed to a RCP. [message #27822 is a reply to message #27761] |
Wed, 11 February 2009 07:38   |
Hi ali,
you can model the flow of your transformation plugins with the JWT
workflow editor. There, you have the possibility to specify which
"applications" shall be executed. Applications could be Java classes, web
services or also plugins. For the moment, we don't have a specific
subclass for Eclipse plugins, but this part of the metamodel is subject of
change, anyway, so we could include your requirement and implement this,
too.
When the process (the order in which your plugins shall be performed) has
been modeled, then you can execute it. There are currently different
possibilities to execute a process: you can generate XPDL code and deploy
it on a workflow engine such as Bonita; you can also generate BPEL code
and execute it on a web service engine or you can call some Java classes
using the JWT Desktop engine (which is alas still not converted to Eclipse
right now and only available on SourceForge).
I guess since you have specific plugins, you can maybe say execute this
Java class from the plugin? But I'm not sure, how the JWT desktop will
behave with non existant Java classes. I guess for this you will only see
a blank monitor.
The use case of executing several plugins is quite an interesting one
which we didn't look into right now, so any requirements that you have are
interesting for us.
Florian
Re: Building JWT workflows between plug-ins contributed to a RCP. [message #27862 is a reply to message #27822] |
Wed, 11 February 2009 09:38  |
Originally posted by: mickael.istria.openwide.fr
Hello ali, hello Florian,
Probably you should take a look at the Modeling Workflow Engine
http://wiki.eclipse.org/Modeling_Workflow_Engine_(MWE) .
This project could be an interesting, light and Eclipse-friendly
workflow engine for your use-case. However, I am not aware of the
current status of this project, and JWT is does not yet allow you to
produce flows in the MWE metamodel (should come one day...).
Hope that helps
Mickael
Florian Lautenbacher a écrit :
> Hi ali,
> web services or also plugins. For the moment, we don't have a specific
> of change, anyway, so we could include your requirement and implement
> this, too.
> has been modeled, then you can execute it. There are currently different
> deploy it on a workflow engine such as Bonita; you can also generate
> BPEL code and execute it on a web service engine or you can call some
> Java classes using the JWT Desktop engine (which is alas still not
> converted to Eclipse right now and only available on SourceForge).
> see a blank monitor.
> are interesting for us.
> Best regards,
> Florian
FUDForum. Page generated in 0.03214 seconds
