Home » Archived » Pulsar » Pulsar Import is not working properly
Pulsar Import is not working properly [message #2366] Sun, 19 July 2009 13:21 Go to next message
I created a j2me project for nokia series 40 (with my existing sources)
and i'm trying to push the same to SVN but with only "MUST HAVE" files for
the project. Here are the files i'm putting in from the main folder
<project_root>:
src
res
mtj
project
classpath
Application Descriptor
build.properties
But when i do an import on this directory structure, it always fails with
the following exception:
Errors occurred during the build.
Errors running builder 'Preprocessor Builder' on project
'samaanguru-mobile'.
[No Message]
[No Message]
Errors running builder 'Preverification Builder' on project
Errors running builder 'Package Builder' on project 'samaanguru-mobile'.
After this the content of build.properties gets overwritten with no file
entries at all. I never have to do anything different on a project folder
with proper .project and .classpath in eclipse. I was wondering what is
causing this issue for Pulsar; can it be fixed soon or am i doing
something wrong?
Appreciate any help/pointers.
-Sumit
Re: Pulsar Import is not working properly [message #2428 is a reply to message #2366] Mon, 20 July 2009 10:47 Go to previous messageGo to next message
can you please file a bug on MTJ about the issue you are facing? MTJ is
the main component on pulsar to develop javame midlets. here is the link
to post the bug
https://bugs.eclipse.org/bugs/enter_bug.cgi?assigned_to=dsdp .mtj-inbox%40eclipse.org&blocked=&bug_file_loc=http% 3A%2F%2F&bug_severity=normal&bug_status=NEW&comm ent=&component=General&contenttypeentry=&content typemethod=autodetect&contenttypeselection=text%2Fplain& amp;data=&dependson=&description=&flag_type-1=X& amp;flag_type-2=X&flag_type-4=X&flag_type-6=X&fl ag_type-7=X&flag_type-8=X&form_name=enter_bug&ke ywords=&maketemplate=Remember%20values%20as%20bookmarkab le%20template&op_sys=Windows%20XP&priority=P3&pr oduct=MTJ&qa_contact=&rep_platform=PC&short_desc =&version=1.0
if you have problems, let me know
gep
Sumit Kumar wrote:
> <project_root>:
> src
> res
> mtj
> project
> classpath
> build.properties
> [No Message]
> java.lang.NullPointerException
> [No Message]
> something wrong?
> -Sumit
Re: Pulsar Import is not working properly [message #2518 is a reply to message #2428] Wed, 22 July 2009 13:47 Go to previous message
Done.. https://bugs.eclipse.org/bugs/show_bug.cgi?id=284310
Thanks GEP!
-Sumit
Re: Pulsar Import is not working properly [message #573996 is a reply to message #2366] Mon, 20 July 2009 10:47 Go to previous message
to post the bug
gep
Sumit Kumar wrote:
> <project_root>:
> src
> res
> mtj
> project
> classpath
> build.properties
> [No Message]
> [No Message]
> something wrong?
> -Sumit
Re: Pulsar Import is not working properly [message #574088 is a reply to message #2428] Wed, 22 July 2009 13:47 Go to previous message
Thanks GEP!
-Sumit
Previous Topic:Programming WinCE with Pulsar
Next Topic:BlackBerry SDK going to be integrated with Pulsar?
Current Time: Wed May 07 17:16:58 EDT 2025
Powered by FUDForum. Page generated in 0.03258 seconds
