Home » Eclipse Projects » Eclipse Platform » Install plugin locally?
Install plugin locally? [message #27702] Tue, 06 May 2003 08:22 Go to next message
Originally posted by: Riedel.Christian.gmx.net
I am relatively new to Eclipse and ran in a slight problem today: I want
to connect to a cvs-server via ssh (protocol version 2). At home I
installed the cvsssh2 plugin and it worked great, but at university
cvsssh2 is not installed.
I discovered, that in my workarea ther is a .metadata/.plugins folder so
I copied the plugin there to try to "install" it locally, but it does
not seem to be loaded. Is it not possible, to install plugins locally
(i.e. for a single user in a multi-user os)? Or have I done anything wrong?
Help would be appreciated.
Thanks in advance
Christian
Re: Install plugin locally? [message #28013 is a reply to message #27702] Tue, 06 May 2003 12:15 Go to previous messageGo to next message
Originally posted by: Kevin.clark.accessbc.com.nospam
It may not be possible... It depends on how your school network is set up.
All plug-in files are located in the ECLIPSE_HOME/plugins/ directory. The
directory you found is part of the workspace, and contains custom
information that saves your workbench state (such as plug-in preference
settings). The actual plug-in files can't go here.
If it is possible with your network, you'll have to copy the cvsssh2
plug-in into the ECLIPSE_HOME/plugins/ directory on your school computer.
Christian Riedel wrote:
> Thanks in advance
> Christian
Re: Install plugin locally? [message #28131 is a reply to message #28013] Tue, 06 May 2003 12:51 Go to previous message
Thanks for the answer,
I am afraid it is not possible for me to install these files. It is a
UNIX system and I do not belong to the admin group. But I asked our sys
admin if he can install the plugin. Maybe he is so kind ;-)
Although it would be cool if it was possible to integrate plugins that
reside in the user-dir.
Thanks anyways.
Christian
Previous Topic:NoSuchMethodError-plugin project and apache libs
Next Topic:UI with swt
Current Time: Sat Aug 02 13:36:12 EDT 2025
Powered by FUDForum. Page generated in 1.03563 seconds
