Home » Eclipse Projects » Eclipse Platform » F1 lookup from JDK API
F1 lookup from JDK API [message #278873] Sun, 09 January 2005 17:29 Go to next message
How can I setup Eclipse 3 so that when I press F1 in Java source file editor
then Eclipse looks up the documentation of the class or method that is under
the cursor? (Like Delphi does)
thanks in advance!
Aivar
Re: F1 lookup from JDK API [message #278885 is a reply to message #278873] Mon, 10 January 2005 05:21 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Aivar Annamaa wrote:
>Hi
If you attach the source you don't even have to press F1: a hover will
show the Javadoc (extracted from the src.zip). Of course you can also
attach the Javadoc, then pressing F1 will show help for the editor and
this popup will contain an entry "Javadoc for ...". To directly open the
Javadoc press Shift+F2.
To attach either source or Javadoc select the JAR in the Package
Explorer and select "Properties" from the context menu.
HTH
Dani
>thanks in advance!
>Aivar
Re: F1 lookup from JDK API [message #278918 is a reply to message #278885] Mon, 10 January 2005 14:43 Go to previous message
Thank you !!!!
this attach source thing is really great!!
Aivar
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:crtkv9$soc$1@www.eclipse.org...
>>Hi
>>editor then Eclipse looks up the documentation of the class or method that
>>is under the cursor? (Like Delphi does)
> To attach either source or Javadoc select the JAR in the Package Explorer
> HTH
> Dani
>>thanks in advance!
>>Aivar
Previous Topic:Where to put a jar to be accessible by a running plugin
Next Topic:rendering problem during changing of perspective
Current Time: Thu Jul 17 13:52:54 EDT 2025
Powered by FUDForum. Page generated in 0.05278 seconds
