Home » Newcomers » Newcomers » Help pls!!
Help pls!! [message #27677] Thu, 17 February 2005 05:19 Go to next message
Originally posted by: gunasekhar.comodo.com
I am using Eclipse 2.1.3 version in Linux
I am using eclipse for c++ programs. Earlier i hv used it for java
programming.
In java, while typing code, if i type any api object and dot(.), i get the
list of methods displayed in pop up menu where i can select the required
method to work.
Now my question is , can i get the same pop-up menu while coding c++
programs?
I tried but its not giving any pop-up.
Is there any thing im missing here?
any help is appreciated
thanks & regards
DGS
Re: Help pls!! [message #27699 is a reply to message #27677] Thu, 17 February 2005 11:20 Go to previous message
Originally posted by: Chris_Laffra.ca.ibm.com
Is your project a CDT project? Or did you just create a C++ file and edit
it?
In order for CDT to discover types, you project has to be enabled for CDT.
There is a wizard for this. File > New > CDT - then something like convert
project. etc.
Did you read the CDT documentation? Help > Help Contents....
Chris Laffra, http://eclipsefaq.org
"DGS" <gunasekhar@comodo.com> wrote in message
news:cv1r3p$smo$1@www.eclipse.org...
> Hi
> programming.
> method to work.
> programs?
> thanks & regards
> DGS
Previous Topic:Set next statement in debugger? (try again)
Next Topic:Hardware requirements
Current Time: Thu Jul 17 20:05:26 EDT 2025
Powered by FUDForum. Page generated in 0.12101 seconds
