Home » Eclipse Projects » Eclipse Platform » Need Help with Internal Error Launching JUnit Test
Need Help with Internal Error Launching JUnit Test [message #277898] Sat, 18 December 2004 13:47
Originally posted by: phodgetts.agilelogic.com
I'm just now starting with Eclipse, so this may a bit of newbie question,
but I didn't see anything similar scanning back through past postings.
I am using Eclipse Version: 3.1.0, Build id: 200411050810, which is listed
as the latest stable 3.1 build.
I'm trying to run a JUnit test. Following the little tutorial in the help
file, I click on my test class, select Run, Run As, JUnit Test from the
menus, and I get the following error dialog box:
An internal error occurred during: "Launching".
I suspect something is messed up with my configuration or installation.
Where do I start looking for the problem? Is there a log file or something
to get more info from? Is this a common problem with an easy solution?
Thanks much in advance,
Paul
Previous Topic:klomp.org SFTP plugin
Next Topic:deprecated
Current Time: Mon Jul 21 23:46:01 EDT 2025
Powered by FUDForum. Page generated in 0.02478 seconds
