| can't start eclipse after error from web browser tab [message #277871] |
Fri, 17 December 2004 16:05 |
Originally posted by: eclipse.nocturnal.org
I'm running an up2date fedora core 3 machine. Eclipse is also up2date at
3.0.1. I clicked on one of the tabs in the console window area and it
caused an error warning I should restart eclipse. I did so and now
eclipse fails when attempting to start. I added /usr/lib/mozilla-1.7.3 to
the ld.so.conf and re-ran ldconfig -v and saw it was added. I did so
after noticing that the libswt-mozilla-gtk-3063.so below didn't see
libxpcom.so anywhere in the path. It didn't help. I'm locked outta
eclipse and can't figure out how to get back in. I assume its trying to
load that same tab I clicked since that is where I left off. Help? Sorry
if this is someplace else. I looked at all the subject lines on the group
and didn't notice it.
ERROR from .metadata/.log
!ENTRY org.eclipse.osgi Dec 17, 2004 14:56:01.743
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: No more handles (java.lang.UnsatisfiedLinkError:
/home/mlenz/eclipse/plugins/org.eclipse.swt.gtk_3.0.1/os/lin ux/x86/libswt-mozilla-gtk-3063.so:
undefined symbol: _ZN9nsCStringC1Ev)
at org.eclipse.swt.SWT.error(SWT.java:2717)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.browser.Browser.<init>(Browser.java:119)
at com.genuitec.eclipse.browser.HTMLViewer.createControl(Unknow n
Source) at com.genuitec.eclipse.browser.HTMLViewer.<init>(Unknown
Source)
at com.genuitec.eclipse.browser.HTMLViewer.<init>(Unknown Source)
at com.genuitec.eclipse.browser.HTMLView.createPartControl(Unkn own
Source)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
org.eclipse.ui.internal.ViewPane.createChildControl(ViewPane .java:135)
at org.eclipse.ui.internal.ViewFactory$1.run(ViewFactory.java:3 51)
org.eclipse.ui.internal.ViewFactory.busyRestoreView(ViewFact ory.java:273)
at org.eclipse.ui.internal.ViewFactory$2.run(ViewFactory.java:5 30)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.ViewFactory.restoreView(ViewFactory. java:528)
org.eclipse.ui.internal.ViewFactory$ViewReference.getPart(Vi ewFactory.java:102)
org.eclipse.ui.internal.WorkbenchPage$1.propertyChange(Workb enchPage.java:132)
org.eclipse.ui.internal.LayoutPart.setVisible(LayoutPart.jav a:268)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 7)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:56 8)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:122)
org.eclipse.ui.internal.presentations.DefaultPartPresentatio n.selectPart(DefaultPartPresentation.java:1116)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:946)
org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:467)
org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:367)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:432)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:155)
org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:732)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2063)
org.eclipse.ui.internal.WorkbenchWindow$4.run(WorkbenchWindo w.java:1858)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:1845)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1409)
org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1224)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 185)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:1096 )
org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1029)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:167)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:652)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:819)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1325)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
END ERROR
FUDForum. Page generated in 0.05145 seconds
