Home » Archived » BIRT » Setting parameters via API
Setting parameters via API [message #277869] Thu, 24 January 2008 16:53
Originally posted by: pmills.systemcore.ca
I'm missing something that I suspect must be obvious. Using the report
engine API, I have no problem running and rendering a report. I also see
calls to find out all kinds of information about report parameters through
the IGetParameterDefinitionTask. What I don't see is the mechanism for
setting a parameter.
Let's say I schedule a report to run every Sunday night to calculate the
past week's activity. In my scheduler code (Java), I know the start and
end times, which I want to map to '?' parameters in my SQL. What chain of
events has to happen?
Previous Topic:Setting parameters via API
Next Topic:Setting parameters via API
Current Time: Fri Jul 25 09:43:32 EDT 2025
Powered by FUDForum. Page generated in 0.04550 seconds
