Home » Eclipse Projects » Eclipse Platform » Launching eclipse
Launching eclipse [message #277528] Mon, 13 December 2004 09:50 Go to next message
Originally posted by: iwan.global.co.za
I am launching eclipse (for testing purposes) from the commandline using
org.eclipse.launcher.Main. How can I install my plugin (under
development) in this launched instance of eclipse? (Or programmatically.)
-Iwan Vosloo
Re: Launching eclipse [message #277576 is a reply to message #277528] Mon, 13 December 2004 14:10 Go to previous messageGo to next message
Originally posted by: lmorley.wpi.edu
If I understand you correctly, you are trying to start a new instance of
Eclipse with your own plug-in included in this new copy. If so, you
would probably want to look at running your plug-in in the Runtime
Workbench; if you have your plug-in in an Eclipse plug-in project, you
can select "Run as Run-time Workbench" from the run menu.
Iwan Vosloo wrote:
> -Iwan Vosloo
Liam Morley
Computer Science Undergraduate
Worcester Polytechnic Institute
Re: Launching eclipse [message #277627 is a reply to message #277576] Tue, 14 December 2004 10:53 Go to previous message
Hi Liam,
you understand me correctly, but I cannot do what you suggest - that is
exactly my problem - I need to be able to duplicate what happens in the
scenario you describe.
-i
> Iwan Vosloo wrote:
>> -Iwan Vosloo
Previous Topic:How to make ProblemsView's filter enable my problemMarker?
Next Topic:Eclipse Guru? Can you solve "Master Table" error
Current Time: Sat Jul 26 14:00:59 EDT 2025
Powered by FUDForum. Page generated in 0.05632 seconds
