Home » Newcomers » Newcomers » Eclipse and Hibernate Tools... Problem
Eclipse and Hibernate Tools... Problem [message #27542] Mon, 14 February 2005 04:43
Originally posted by: rolandz.poczta.fm
I am new to eclipse as well as to java. However I'm an expert on
C++/C#/.NET - so it helps me a lot :-)
Currently I am trying to use Hibernate with java/Eclipse (I am using
NHibernate so this is quite familiar to me...). Downloaded Eclipse
plugins/tools from Hibernate site.
And now... I have created hibernate configuration file for my FireBird
database using the plugin tool in eclipse. It was easy... Now I switch to
Hibernate Console perspective and try to create a session. And getting
following error:
--- Exception: ---
Error lut 10, 2005 19:30:56.128 Exception while connecting/starting Hibernate
org.hibernate.console.HibernateConsoleRuntimeException: Problems while
loading database driverclass (org.firebirdsql.jdbc.FBDriver)
org.hibernate.console.ConsoleConfiguration.registerFakeDrive r(ConsoleConfiguration.java:195)
org.hibernate.console.ConsoleConfiguration.buildWith(Console Configuration.java:155)
org.hibernate.console.ConsoleConfiguration.build(ConsoleConf iguration.java:128)
org.hibernate.eclipse.console.actions.BuildSessionFactoryAct ion.doRun(BuildSessionFactoryAction.java:50)
org.hibernate.eclipse.console.actions.ConsoleConfigurationBa sedAction.run(ConsoleConfigurationBasedAction.java:47)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:167)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:555)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:505)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:419)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2803)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2448)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1569)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1540)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:220)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
Caused by: java.lang.ClassNotFoundException: org.firebirdsql.jdbc.FBDriver
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:404)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.hibernate.util.ReflectHelper.classForName(ReflectHelper. java:103)
org.hibernate.console.ConsoleConfiguration.registerFakeDrive r(ConsoleConfiguration.java:187)
... 27 more
The question is why.. It does not matter whether I have any referrence to
the driver in my project or not. I seems that Eclipse itself does not find
the driver rather than any other site...
TIA
Roland
Previous Topic:Eclipse crashes at random times (Linux)
Next Topic:A lot of windows in Gnome
Current Time: Sat Oct 18 16:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.11609 seconds
