Home » Eclipse Projects » Eclipse Platform » Associating and Opening Editors
Associating and Opening Editors [message #27539] Mon, 05 May 2003 09:26 Go to next message
I would like to know how to accomplish the following:
1. How to associate an editor with an object type instead of a file
extension.
2. How to open an editor programatically.
All help is appreciated
Re: Associating and Opening Editors [message #27638 is a reply to message #27539] Mon, 05 May 2003 13:53 Go to previous messageGo to next message
> extension.
IWorkbenchPage activePage =
getActiveWorkbenchWindow().getActivePage();
activePage.closeEditor(oldTaskEditor, false);
// open new editor
IFile destination = root.getFile(newLocation);
activePage.openEditor(destination);
Re: Associating and Opening Editors [message #28209 is a reply to message #27539] Tue, 06 May 2003 13:25 Go to previous messageGo to next message
> extension.
Have a look at IEditorInput interface. By writing your own editor input,
you can open a custom editor on pretty much anything. You will still
have to open it programmatically though.
This is not a big limitation; you have your own object model that you
want to edit and chances are you also want to present this model to the
user in a custom view. For example, Package Explorer shows packages and
JAR file contents for Java projects. Once you have a custom view, you
can invoke your editor programatically, responding to user selections.
Re: Associating and Opening Editors [message #28327 is a reply to message #27638] Tue, 06 May 2003 14:12 Go to previous messageGo to next message
What is the root object?
Is it possible to opent the editor and/or associate the editor with an
object type rather than a file.
Thanks for the help
"Todd Chambery" <chambery@us.ibm.com> wrote in message
news:b96mlb$4fa$1@rogue.oti.com...
> > extension.
> // open new editor
Re: Associating and Opening Editors [message #28549 is a reply to message #28209] Tue, 06 May 2003 22:15 Go to previous messageGo to next message
Thanks. Do you know how that would affect the 'editors' section in the
plugin.xml? WOuld I still need and entry for this editor?
"Cagatay Kavukcuoglu" <cagatayk@stop.acm.org> wrote in message
news:b98r80$inr$1@rogue.oti.com...
> > extension.
Re: Associating and Opening Editors [message #28625 is a reply to message #28549] Wed, 07 May 2003 10:59 Go to previous message
Yes, you would. However, you could omit the optional "extensions"
attribute to the "editor" element of the extension.
>>>extension.
Previous Topic:MenuManagers and Sub-Menus
Next Topic:failed to import classes in default packages
Current Time: Fri Jul 18 22:49:22 EDT 2025
Powered by FUDForum. Page generated in 0.04685 seconds
