Home » Eclipse Projects » Eclipse Platform » Using org.eclipse.ui.popupMenus and objectContribution without view or editor....
Using org.eclipse.ui.popupMenus and objectContribution without view or editor.... [message #277257] Tue, 07 December 2004 13:19
My plugin uses a view, when clicking somewhere in this view (not
important) a dialog appears and a TableTreeViewer displays a list of
AnalyzableObject object (it implements the IAdaptable interface). I
defined a menu manager for this TableTree and add in my plugin.xml file
the needed popuMenu extension for this type of object.
Finally, I added an AnalyzeObjectActionDelegate.
NOTHING appears !!! I think this is the way I create my menu manager:
It is empty and only fill by plugins which wants add functionalities for
this object, so it contains an "Addition" Seperator object and that all.
What can I do to have my popup appear ??
Thanks.
Previous Topic:Using getSite().registerContextMenu() issue.
Next Topic:HOWTO remove old launch-config from "XML"?
Current Time: Wed Nov 19 06:38:45 EST 2025
Powered by FUDForum. Page generated in 0.03920 seconds
