Home » Eclipse Projects » Eclipse Platform » Problems with workspace starting up
Problems with workspace starting up [message #27531] Mon, 05 May 2003 09:01 Go to next message
Originally posted by: eclipse.wingspread.fastmail.fm
I'm using Eclipse 2.1 on a Windows XP machine. Yesterday Eclipse crashed
due to an out of memory condition. Since that time I have been unable to
open Eclipse without getting errors on startup or exit. When I start
Eclipse, I see information such as the following in my log:
!SESSION May 05, 2003 08:55:01.110 -----------------------------------------
java.version=1.4.1_01
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/dev/java/eclipse2.1/
!ENTRY org.eclipse.core.runtime 4 2 May 05, 2003 08:55:01.110
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2332)
at org.eclipse.swt.SWT.error(SWT.java:2262)
at org.eclipse.swt.widgets.Widget.error(Widget.java:385)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:246)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:237)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:190)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:128)
org.eclipse.jface.resource.FontRegistry.defaultFont(FontRegi stry.java:293)
at org.eclipse.jface.resource.FontRegistry.get(FontRegistry.jav a:370)
org.eclipse.jface.resource.JFaceResources.getFont(JFaceResou rces.java:183)
at org.eclipse.jdt.internal.ui.JavaPlugin.startup(JavaPlugin.ja va:241)
!ENTRY org.eclipse.core.runtime 4 2 May 05, 2003 08:55:01.157
!MESSAGE Plug-in org.eclipse.ajdt.ui was unable to load class
org.eclipse.ajdt.internal.builder.Builder.
!STACK 0
org.eclipse.core.internal.boot.DelegatingLoaderException:
org.eclipse.core.runtime.CoreException: Problems encountered starting up
plug-in: "org.eclipse.jdt.ui".
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:746)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:112)
!ENTRY org.eclipse.core.resources 2 1 May 05, 2003 08:55:01.157
!MESSAGE Skipping builder org.eclipse.ajdt.ui.ajbuilder for project CACM.
Either the builder is missing from the install, or it belongs to a project
nature that is missing or disabled.
!ENTRY org.eclipse.core.runtime 4 2 May 05, 2003 08:55:01.188
!STACK 0
org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gatingLoaderException:
Attempt to load class "org.eclipse.ajdt.internal.builder.Builder" from
deactivated plug-in "org.eclipse.ajdt.ui".
org.eclipse.core.internal.plugins.PluginClassLoader.shouldLo okForClass(PluginClassLoader.java:255)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:174)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf(DelegatingURLClassLoader.java:485)
!ENTRY org.eclipse.core.resources 2 1 May 05, 2003 08:55:01.188
CreditGrades Workbench. Either the builder is missing from the install, or
it belongs to a project nature that is missing or disabled.
!ENTRY org.eclipse.core.runtime 4 2 May 05, 2003 08:55:01.219
!STACK 0
Clearly something is hosed in my setup. The question is what, if anything,
can I do to get things working properly again?
Thanks.
James Howe
Re: Problems with workspace starting up [message #27541 is a reply to message #27531] Mon, 05 May 2003 09:21 Go to previous message
I would report this problem to the provider of the plugin
(org.eclipse.ajdt.ui) that contains this builder reported as having trouble.
Looks to be the root of the problem.
You could also ask on eclipse.technology.ajdt?
I would remove this plugin and see how things go?
HTH
Darins
"James Howe" <eclipse@wingspread.fastmail.fm> wrote in message
news:opropahabbxx2sji@news.eclipse.org...
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> !STACK 0
> at
> at
> at
ssLoader.java:112)
> !STACK 0
ption:
> at
> at
> at
> !STACK 0
ption:
> at
> at
> at
anything,
> Thanks.
> James Howe
Previous Topic:Plug-In it works no more
Next Topic:Access ContentOutline selection from PlatformUI
Current Time: Sat Aug 30 15:03:49 EDT 2025
Powered by FUDForum. Page generated in 0.02396 seconds
