Eclipse very slow on Win XP [message #276583] |
Thu, 25 November 2004 18:29  |
Originally posted by: marco_lamanna.libero.it
Hello everybody,
I'm an happy user of Eclipse but sometimes it hangs on and I have to wait
minutes to let him return to work. I noticed my HD led is always on. It
hangs also when I try to open a file from my active project...
My system is: Notebook P4 2.8 Ghz 521MB DDR 333 on WinXP SP2.
Thank for your attention and sorry for my English.
Regards.
Marco
Re: Eclipse very slow on Win XP [message #284439 is a reply to message #283660] |
Mon, 25 April 2005 05:10  |
tojotamies wrote:
>> Marco Luca Lamanna wrote:
>>> Hello everybody,
>>> wait minutes to let him return to work. I noticed my HD led is always
>>> on. It hangs also when I try to open a file from my active project...
>> Most likely the problem is a combination of windows memory management
>> (Windows XP is very aggressive about swapping programs to virtual
>> memory, even when you don't want them to be), and the fact that laptop
>> hard drives are usually very slow.
>> There is a plugin for Eclipse called "Keep Resident" that might help
>> prevent windoze from swapping Eclipse out so much. If you have enough
>> RAM you could also try disabling the swap file in windows.
>> HTH,
>> Eric
> Thanks Eric! I had the same problem, but with the KEEP RESIDENT PLUGIN
> the problem is gone!
> Cheers,
> tojotamies
I celebrated too soon... :( - the problem is not gone. Next I will try
to disable the swap-file. Im using Win XP pro, 512 MB, 3GHz
Fujitsu-Siemens Amilo D 8830 laptop.
tojotamies
FUDForum. Page generated in 0.54165 seconds
