Home » Eclipse Projects » Eclipse Platform » [ANN] Solaris-GTK (Sparc) joins the build lineup
[ANN] Solaris-GTK (Sparc) joins the build lineup [message #276449] Tue, 23 November 2004 14:34
As of today's integration build, Solaris-GTK (Sparc) will be built as a
regular supported configuration. Similar to Linux-GTK, you just need to
ensure that your installed GTK+ libraries are on your LD_LIBRARY_PATH
(usually /usr/local/lib/). An easy place to download GTK+ for Solaris is
http://www.sunfreeware.com/ .
Solaris users looking for an alternative to Solaris-motif are encouraged to
try out the new builds and to log any bugs found (it's been quite stable so
far). There will be a Solaris-GTK tag added to Bugzilla's OS field shortly.
Grant
Previous Topic:java meta model
Next Topic:Toolbars
Current Time: Sun Aug 31 18:28:12 EDT 2025
Powered by FUDForum. Page generated in 0.03386 seconds
