Home » Eclipse Projects » Eclipse Platform » NoClassDefFoundError on new InitialContex()
NoClassDefFoundError on new InitialContex() [message #27421] Fri, 02 May 2003 15:33 Go to next message
Originally posted by: leena.blackpearl.com
I'm trying to lookup a Jndi DataSource from Eclipse, using WL8.1. I have
been successful using WL61, so i just replaced the weblogic.jar in my
classpath with the 81 jar file, but i am unable to connect now.
I get a NoClassDefFoundError for weblogic.rmi.extensions.server.Stub,
which is present in weblogic.jar! This happens when i do a "new
InitialContext(env);" call.
I am able to load other classes from this jar file - for ex,
weblogic.jndi.WLInitialContextFactory, but it doesnt seem to find the
Stub.class.
I must mention that i initially had trouble finding the
WLInitialContextFactory.class(even in 6.1), but i saw a posting on this
newsgroup on how to find 3rd party jars from the plugin classpath by
changing the classloader..Someone(Thank you!) suggested to do this:
Thread.currentThread().setContextClassLoader(myClass.getClas sLoader());
Is this making a difference ? But if i dont have this line, i am unable to
pick up webloigic. jar at all.
Any ideas ? Any suggestions are welcome. I am at a loss on how to
proceed now..
Thanks in advance,
Leena.
Re: NoClassDefFoundError on new InitialContex() [message #27592 is a reply to message #27421] Mon, 05 May 2003 13:30 Go to previous message
Just posting again to see if anyone has any ideas at all....I did forget
to mention that i am accessing WL from my own plugin, and my plugin.xml
has an entry for weblogic.jar, and my plugin dir has the jar file.
Any help would be really appreciated,
Leena.
Leena wrote:
> I\'m trying to lookup a Jndi DataSource from Eclipse, using WL8.1. I have
> which is present in weblogic.jar! This happens when i do a \"new
> InitialContext(env);\" call.
> Stub.class.
> proceed now..
> Thanks in advance,
> Leena.
Previous Topic:how to launch java applications programmatically?
Next Topic:Internation chars become ? after saved/closed and reopened
Current Time: Fri Jul 18 03:33:39 EDT 2025
Powered by FUDForum. Page generated in 0.08245 seconds
