Re: split view of same file [message #276177 is a reply to message #276173] |
Thu, 18 November 2004 17:07   |
Originally posted by: michaelm.nospam.invalid.net
On Thu, 18 Nov 2004 15:32:13 -0500, I wrote:
>On Thu, 18 Nov 2004 16:25:23 +0000 (UTC), leo@nowhere.com (LeO) wrote:
>>But there is already a patch for 3.0.1
>>https://bugs.eclipse.org/bugs/show_bug.cgi?id=8009
>Thanks, I downloaded the patch. The instructions say:
>"To patch it is best to download a clean eclipse binary install kit,
>unpack it, then unpack this zip to a temporary folder on your
>filesystem. copy the org.eclipse.ui.workbench.texteditor_3.0.1 folder
>into the newly installed eclipse plugin directory to overwrite the
>current workbench.texteditor plugin. Next, use the clasess under
>"classes" to update the jar in the org.eclipse.ui.workbench_3.0.1 to
>have the new WorkbenchPage and IWorkbenchPage classes."
>I do not understand the last sentence. What action am I supposed to do
>to make the plug-in work? It currently doesn't do anything as I don't
>follow the last sentence of the above. How do you "update the jar"?
Ok, I used WinZip to add to the workbench.jar the WorkbenchPage and
IWorkbenchPage classes. However, Ctrl-2 still doesn't do anything...
Anyone got this working with Eclipse 3.0.1 and CDT 2.0.2?
Michael McCulloch
Re: split view of same file [message #276178 is a reply to message #276177] |
Thu, 18 November 2004 17:34   |
On Thu, 18 Nov 2004 17:07:35 -0500, Michael McCulloch
Well, this is a nice conversation I'm having with myself...
Ok. I have the patch working. The key was that the path shown in
Winzip when I added the files has to match the folder structure
already there, namely "org/eclipse/ui/" for the IWorkbenchPage.class
file and "org/eclipse/ui/internal" for the other classes.
You can trick Winzip into doing this by copying the org folder (and
all subfolders) of the org.eclipse.ui.workbench_3.0.1 patch tree to
the root level of your C drive. Then use Winzip to "Freshen" the
workbench.jar and be sure to check "Save full path info".
Hope that helps someone else. The patch seems to work fine with CDT
2.0.2.
Michael McCulloch
FUDForum. Page generated in 0.07339 seconds
