Home » Eclipse Projects » Eclipse Platform » How to force workbench to query ISaveableParts
How to force workbench to query ISaveableParts [message #275600] Tue, 09 November 2004 15:32 Go to next message
Originally posted by: cebarne2.rockwellcollins.REMOVETHIS.com
I have a view that implements ISaveablePart. If I mark the view as dirty,
nothing happens regarding the workbench save icon until I switch to another
view and back to my view. It seems that when the view is brought to the
front, it notifies the workbench and the isDirty() method is called.
I would like to force the workbench to respond when I manually set the view
as dirty. I have a task list in the view. When I add a new task, I want to
set the view dirty and make the workbench change its save icon to reflect
the view's state. How can I do this? What command causes the workbench to
run this query?
Chad Barnes
Rockwell Collins Inc.
Re: How to force workbench to query ISaveableParts [message #275604 is a reply to message #275600] Tue, 09 November 2004 16:35 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
You are confusing Views with Editors. Views cannot become 'dirty'.
Only editors can. See http://www.eclipsefaq.org/chris/faq/html/faq206.html
Chris
"Chad Barnes" <cebarne2@rockwellcollins.REMOVETHIS.com> wrote in message
news:cmr9fj$18b$1@eclipse.org...
another
view
to
to
> run this query?
> Chad Barnes
Re: How to force workbench to query ISaveableParts [message #275615 is a reply to message #275604] Tue, 09 November 2004 20:17 Go to previous messageGo to next message
Chris,
Thanks for the quick reply.
I think I found the answer in the following thread:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg00419.html
To make this work correctly, I needed to call
firePropertyChange(ISaveablePart.PROP_DIRTY) in my setDirty() method.
Are the official Eclipse 3.0 faqs still valid to say a view cannot be dirty
in light of this functionality?
Chad Barnes
"Chris Laffra" <Chris_Laffra@ca.ibm.com> wrote in message
news:cmrd59$81m$1@eclipse.org...
> Chris
dirty,
> another
> view
want
> to
reflect
> to
> > run this query?
> > Thanks,
> > Chad Barnes
Re: How to force workbench to query ISaveableParts [message #275646 is a reply to message #275615] Wed, 10 November 2004 09:46 Go to previous message
FAQ 206 outlines the "rules of engagement" for Views and Editors. It is
based on 3.0
(hence the title of the book).
You are showing API introduced after 3.0 was released.
The reason was that enough people have been "breaking the rules" for Eclipse
to adapt.
Being a flexible open source project, it will support changes requested by
the community.
If you have a view that really needs a dirty state and needs to be saved
when closed,
reconsider, and see if an editor is more appropriate.
Users have expectations, and it is appropriate to abide by them.
Chris
news:cmrq5t$sqj$1@eclipse.org...
> Chris,
dirty
> Thanks
> Chad Barnes
> > Chris
> dirty,
> > another
the
> > view
> want
> > to
> reflect
workbench
> > to
> > > run this query?
> > > Thanks,
> > > Chad Barnes
Previous Topic:How do I display an icon defined in plugin.xml
Next Topic:Coloring keywords in SourceViewer
Current Time: Thu Jul 17 09:11:33 EDT 2025
Powered by FUDForum. Page generated in 0.11049 seconds
