Home » Eclipse Projects » Buckminster dev » Exception: No enum const
Exception: No enum const [message #27293] Fri, 07 November 2008 09:46 Go to next message
Originally posted by: erdal.karaca.airbus.com
I think this happens when buckminster tries to resolve plugins from target
platform...
If I execute a cquery which does not depend on the target platform's
plugins this will not happen.
I am using the "latest" publication of buckminster (from buckminster
update site)
Stack Trace:
java.lang.IllegalArgumentException: No enum const class
org.eclipse.buckminster.pde.internal.EclipsePlatformVersionF inder$InstalledType.PLUGINS
at java.lang.Enum.valueOf(Unknown Source)
org.eclipse.buckminster.pde.internal.EclipsePlatformVersionF inder$InstalledType.valueOf(EclipsePlatformVersionFinder.jav a:1)
org.eclipse.buckminster.pde.internal.EclipsePlatformVersionF inder. <init>(EclipsePlatformVersionFinder.java:50)
org.eclipse.buckminster.pde.internal.EclipsePlatformReaderTy pe.getVersionFinder(EclipsePlatformReaderType.java:312)
org.eclipse.buckminster.core.rmap.model.Provider.findMatch(P rovider.java:218)
org.eclipse.buckminster.core.rmap.model.SearchPath.getProvid er(SearchPath.java:104)
org.eclipse.buckminster.core.rmap.model.ResourceMap.resolve( ResourceMap.java:173)
org.eclipse.buckminster.core.resolver.ResourceMapResolver.in nerResolve(ResourceMapResolver.java:251)
org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.re solve(ResolverNodeWithJob.java:218)
org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.ru n(ResolverNodeWithJob.java:95)
org.eclipse.buckminster.core.resolver.ResolverNodeWithJob$No deResolutionJob.run(ResolverNodeWithJob.java:50)
Re: Exception: No enum const [message #27734 is a reply to message #27293] Fri, 07 November 2008 09:50 Go to previous messageGo to next message
this is my rmap:
-%snip----------------------------------
... some other searchPaths which depend on target platform's plugins...
<searchPath name="tp">
<provider readerType="eclipse.platform"
componentTypes="eclipse.feature,osgi.bundle,buckminster" source="true"
mutable="false">
<uri format="plugins/{0}">
<bc:propertyRef key="buckminster.component" />
</uri>
</provider>
</searchPath>
... locators of other searchPaths...
<locator searchPathRef="tp" pattern=".*" />
Re: Exception: No enum const [message #27753 is a reply to message #27734] Fri, 07 November 2008 10:18 Go to previous messageGo to next message
Hi Erdal,
You are not supposed to use the eclipse.platform reader type in the rmap. It's for
internal use only. The target platform will be consulted by default when resolving
components unless you explicitly disable it in a CQUERY advisor node.
Thomas Hallgren
Erdal Karaca wrote:
> this is my rmap:
> source="true"
> mutable="false">
> </uri>
> </provider>
> </searchPath>
Re: Exception: No enum const [message #27787 is a reply to message #27753] Fri, 07 November 2008 10:23 Go to previous messageGo to next message
I see. Yet, this should be mentioned in the "component meta-data language"
reference...
Re: Exception: No enum const [message #28869 is a reply to message #27787] Mon, 24 November 2008 19:48 Go to previous message
> language" reference...
It would be really helpful if you could log a bugzilla issue.
Previous Topic:Broken Suclipse buckminster headless ?
Next Topic:Is a tighter leash needed on projects participating in the next release train?
Current Time: Thu Jul 17 21:58:39 EDT 2025
Powered by FUDForum. Page generated in 0.08396 seconds
