Can 3.0.1 co-exist with 2.1.3? [message #274381] |
Wed, 20 October 2004 16:56  |
Originally posted by: rhino1.NOSPAM.sympatico.ca
I have Eclipse 2.1.3 on my Windows XP machine and would also like to try
Eclipe 3.0.1. Can the two co-exist on this machine without messing each
other up?
What is the best way to install 3.0.1 without causing a clash with 2.1.3?
I'd like to be able to run either at any time. Will I be able to run both at
the same time if that becomes necessary?
What is involved in migrating projects over from 2.1.3 to 3.0.1, including
both Java projects and Tomcat projects?
Is there any functionality from 2.1.3 that isn't present in 3.0.1 or that
works very differently? For example, I seem to recall something about
plug-in development being different between the 2.x and 3.x streams but I'm
not presently developing plug-ins.
Rhino
rhino1 AT sympatico DOT ca
"There are two ways of constructing a software design. One way is to make it
so simple that there are obviously no deficiencies. And the other way is to
make it so complicated that there are no obvious deficiencies." - C.A.R.
Hoare
Re: Can 3.0.1 co-exist with 2.1.3? [message #274449 is a reply to message #274403] |
Thu, 21 October 2004 12:50  |
Originally posted by: eclipse.rizzoweb.com
Beth Tibbitts wrote:
> My usual installation goes something like this:
> Unzip eclipse into a dir whose name is the release, e.g. on win32,
> c:\eclipse-3.0.1 and
> c:\eclipse-2.1.3
> Then you can have as many installations/versions as you like.
> I don't unzip to the root directory, because of this.
> Thus the executable is in e.g. c:\eclipse-3.0.1\eclipse\eclipse.exe
> Also, use the -data arg on eclipse invocation to specify the workspace
> (don't mix up your 2.x and 3.x workspaces)
In addition to installing into a separate directory, you can just copy
over your 2.1 workspace into a new location and open that copied version
in 3.0. Eclipse 3 will automatically migrate the workspace, but once it
does so that workspace location can't be used by 2.x any more. So keep
the original 2.x workspace separate.
If you do this you may get some warnings the first time because the new
Eclipse version doesn't have all the same plugins as the old 2.x might
have. If that happens, just go through all the way, close all editors
and perspectives (maybe except for Resource Navigator), exit Eclipse and
restart. The second time it starts any warnings should be gone. You can
then re-open the perspectives you want and start editing files.
My installation looks like this:
Java/
Eclipse/
2.1/
3.0/
3.0.1/
workspaces/
2.1/
3.0/
3.0.1/
The workspaces/3.0 directory was originally just a copy of the
workspaces/2.1, and the 3.0.1 was originally a copy of the 3.0
I'm actually going to delete the 2.1 stuff this week, since I feel
comfortable enough with 3.0 and I don't want 2.1 hanging around any more
taking up disk space ;-) But this is my migration strategy every time,
so that I can always go back to the previous version if I want to.
HTH,
Eric
FUDForum. Page generated in 0.10875 seconds
