Home » Archived » BIRT » Latest in CVS
Latest in CVS [message #27232] Sun, 17 April 2005 15:49 Go to next message
Originally posted by: mbatchelor.no_s_p_a_m.pentaho.com
Hey all,
The latest code in CVS has a problem with the viewer. When you try to view a
report, you get the following errors:
Error Message
Semantic errors in
d:\japps\runtime-workbench-workspace\TestProject\freshNewBui ld.rptdesign.
The extension name of element "OdaDataSource" must be defined.
The extension name of element "OdaDataSet" must be defined.
The exceptions are being thrown by
org.eclipse.birt.report.model.parser.ReportElementState in the
parseExtensionName method. It seems that the parser is expecting the
extension name to be in the XML for OdaDataSource and OdaDataSet.
if ( StringUtil.isBlank( extensionName ) )
RecoverableError.dealMissingInvalidExtension( handler,
new SemanticError( element,
SemanticError.DESIGN_EXCEPTION_MISSING_EXTENSION ) );
Any hint where I should fix things so that this is being done properly?
Marc
Re: Latest in CVS [message #27269 is a reply to message #27232] Sun, 17 April 2005 16:20 Go to previous messageGo to next message
I was able to work around the problem by commenting out a line in
OdaDataSetState and OdaDataSourceState:
public void parseAttrs( Attributes attrs ) throws XMLParserException
// parseExtensionName( attrs ); // This is the line I commented out
initElement( attrs, true );
Seems to me that the chart registers itself as an Extension, but
OdaDataSource and OdaDataSet do not. So, when I added
extensionName="OdaDataSource" to the attributes of my OdaDataSource, it was
able to find the attribute OK, but it isn't in the MetaDataDictionary.
Which way is this supposed to go? An alternate fix for this problem could be
to register them in the Extension map in the MetaDataDictionary. But, I
suspect that it really doesn't belong there.
Take care,
Marc
"Marc Batchelor" <mbatchelor@no_s_p_a_m.pentaho.com> wrote in message
news:d3uf1i$7rt$1@news.eclipse.org...
> Hey all,
a
> Error Message
> Semantic errors in
> Marc
Re: Latest in CVS [message #29183 is a reply to message #27232] Wed, 20 April 2005 22:01 Go to previous message
Marc,
As you might have already observed, this problem has been fixed in the latest
source.
Linda
Marc Batchelor wrote:
> Hey all,
> Error Message
> Semantic errors in
> Marc
Previous Topic:ExternalEditor documentation
Next Topic:DataSet Types
Current Time: Thu Jul 17 11:10:26 EDT 2025
Powered by FUDForum. Page generated in 1.14671 seconds
