Re: Problem in the taipan example,"diagramLabel not been set" [message #27360 is a reply to message #27197] |
Wed, 23 August 2006 10:53   |
Hi, thank you for your reply.I have followed your advice to set diagram
lable for every lable mapping. When I try to "Create generator Model..",
it still gave the mistakes
Diagnosis of
org.eclipse.gmf.codegen.gmfgen.impl.GenEditorGeneratorImpl@1e09588 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfgen#/}
The required feature 'targetMetaFeature' of
'org.eclipse.gmf.codegen.gmfgen.impl.TypeLinkModelFacetImpl@1d67a9f {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfgen#//@diagram/@links.0/@modelFacet}'
must be set
'org.eclipse.gmf.codegen.gmfgen.impl.TypeLinkModelFacetImpl@c9615 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfgen#//@diagram/@links.1/@modelFacet}'
must be set
'org.eclipse.gmf.codegen.gmfgen.impl.TypeLinkModelFacetImpl@517317 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfgen#//@diagram/@links.2/@modelFacet}'
must be set
It seems some diagram lables have not been set. But I can not find them.I
can not attach the screen snapshot to here. I think I have set all the
label diagrams in the Hi, I have followed your advice to set diagram lable
for every lable mapping. When I try to "Create generator Model..", it
Diagnosis of
must be set
must be set
must be set
It seems some diagram lables have not been set. But I can not find them. I
can not attch the screen snapshot to here. I think I have set all the
label mapping in
platform:/resource/org.eclipse.gmf.examples.taipan/model.tai pan.gmfmap.
Madanagopal wrote:
> Navigate to the Label Mapping in taipan.gmfmap and select appropriate
> DiagramLabel from the properties view (RightClick on Label Mapping -> Show
> properties View).
> for selecting diagram labels, you can refer to taipan.gmfgraph.
> see the snapshot if you still have troubles.
> On Wed, 23 Aug 2006 15:29:48 +0200, lei <lxu@tssg.org> wrote:
>> Hello, everyone
>> I follow the step of tutorial to implement an example. I choose the
>> ecore of the example taipan (taipan.ecore). When I try to "create
>> generator model..", it cast mistakes.
>> Diagnosis of
org.eclipse.gmf.mappings.impl.MappingImpl@16f0858 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#/}
>> The required feature 'diagramLabel' of
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@97974f {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@nodes.0/@ownedChild/@labelMappings.0}'
>> must be set
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@4ef200 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@nodes.1/@ownedChild/@labelMappings.0}'
>> must be set
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@5e5a7e {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@nodes.2/@ownedChild/@labelMappings.0}'
>> must be set
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@870769 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@links.0/@labelMappings.0}'
>> must be set
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@f77ec4 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@links.1/@labelMappings.0}'
>> must be set
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@a386c4 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@links.2/@labelMappings.0}'
>> must be set
>> when creating the GMFGraph Simple Model and GMFTool Simle Model, I do
>> not change anything the system given(all the elements in list are
>> chosen).
>> Does anyone the reason and possible solution for the problem?
>> Thanks!
Re: Problem in the taipan example,"diagramLabel not been set" [message #29076 is a reply to message #27931] |
Thu, 24 August 2006 11:21  |
After setting "Target Feature", I generate the *.gmfgen file. After that I
try to generate diagram code. It shows errors "InvocationTargetException",
how can i deal with it ?
Also can anyone tell where can I find a detail GMF example. I means it
gives lots of details of every step. How to set ? how those setting effect
the result? Thanks a lot
FUDForum. Page generated in 0.03361 seconds
