An issue in EcoreEnvironment for extensibility [message #26962] |
Thu, 07 June 2007 05:21  |
Originally posted by: alu2526.etsii.ull.es
Hi Christian,
Im in the battle again ;)
I would be very pleased if in the constructor EcoreEnvironment (Registry,
Resource) the TypeResolver is created with a factoryMethod
(createTypeResolver(Resource)) in order to extend EcoreEnvironment and
TypeResolverImpl with my OMEnvironment and OMTypeResolver with a resource as
constructor's parameter.
Im persisting the generated types by the TypeResolver in the same resource
where i have my output OM Model, and I have had some problems. I have some
ideas about the reason, but i need to research more about them. I will post
you as soon as i find out the problem.
Re: An issue in EcoreEnvironment for extensibility [message #27239 is a reply to message #27121] |
Thu, 07 June 2007 11:45  |
Hi Christian,
Some comments
> This sounds like a very sensible refactoring. Please raise an enhancement
> request in bugzilla for it.
Sure it is ;)
Raised as https://bugs.eclipse.org/bugs/show_bug.cgi?id=191504
>> resource
>> some
>> post you as soon as i find out the problem.
It was my fault. I had not created the return type of a mapping operation
(which had not return value), and later an operationCallExp didnt work well.
I have successfully persisted all the collection types created during the
parsing in the same resource where i persist the output model ;)
Greetings !!!!
Adolfo
FUDForum. Page generated in 0.04872 seconds
