ocl newbie question [message #26912] |
Thu, 02 March 2006 15:29  |
Originally posted by: saya.txesystems.com
I have been experimenting with emf's ocl and I have a related question.
I form the following expression:
exp = QueryFactory.eINSTANCE.createQuery(
"self.declaredFacets->asSet()->union(self.superTypes.declaredFacets)- >asSet())",
CorePackage.eINSTANCE.getPartyType());
PartyType is an EObject.It has supertypes of EObjects. It has an
eStructuralFeature declaredFacets. When I evaluate this expression on a
PartyType object which has two declared facets but no superType, I get an
"IllegalArgumentException: Illegal operation(null.union(null)".
When I change the expression to:
"self.declaredFacets->asSet()->union(self.superTypes->asSet()- >collect(p :
PartyType|p.declaredFacets)->asSet())",
everything works fine. Do I have to use collect whenever an eStructural
feature (in this case superTypes) might return null, is this a bug or am I
doing something wrong?
I would appreciate any comments,
thanks,
Selcuk
Re: ocl newbie question [message #26993 is a reply to message #26912] |
Thu, 02 March 2006 17:53  |
Hi, Selcuk,
You should never need to use an explicit collect iterator in place of the
dot notation when the collect would simply navigate another reference; the
notations are equivalent.
There definitely is a bug, here. I can parse the following expression:
IOCLHelper helper = HelperUtil.createOclHelper();
helper.setContext(ExpressionsPackage.eINSTANCE);
OCLExpression expr = helper.createQuery(
"self.eClassifiers->asSet()->union(" +
"self.eSubpackages->collect(eClassifiers)->asSet())");
but not this:
self.eSubpackages.eClassifiers->asSet())
which should work equally well. Instead, I get a "No common supertype:
(EClassifier), (null)". It seems that in my case and yours, the parser
cannot determine the type of a dot navigation expression through two
collections.
I have raised https://bugs.eclipse.org/bugs/show_bug.cgi?id=130239 to
address this problem.
Christian
Selcuk Aya wrote:
> thanks,
> Selcuk
Re: ocl newbie question [message #571230 is a reply to message #26912] |
Hi, Selcuk,
but not this:
collections.
Christian
Selcuk Aya wrote:
> thanks,
> Selcuk
FUDForum. Page generated in 0.05128 seconds
